3-D scanning and point cloud-based inspection on the wing of the Boeing 787 Dreamliner
Nikon Metrology Inc. Published: 04/22/2010
A
few years ago a Missouri-based casting company, O’Fallon Casting, realized that its touch probe-based inspection system was stretched to the limit for most of its rapid prototyping work. O’Fallon Casting took a new approach by installing a cross scanner from Nikon Metrology plus PolyWorks software from InnovMetric Inc.
A prototyping project, involving the housing for an integrated wing-tip light of the Boeing 787 Dreamliner, illustrates the innovation of 3-D scanning and point cloud-based inspection. O’Fallon engineers inspected both the housing’s foam pattern and inherent aluminum part, and managed to cut the entire process throughput time by 50 percent. More important, the countless measurement points they had acquired and the CAD comparison analysis graphics enabled them to better supervise the process and eliminate prototype rounds while delivering top quality.
O’Fallon Casting is a nonferrous investment casting company that has built its reputation on making high-quality, competitively priced castings to meet demanding end-user applications. In its 50,000 square foot facility, the company is specialized in casting a range of aluminum, copper-based, and silicon carbide metal matrix composite alloys, and furnishes castings only or castings machined to customer specifications, for electronic packaging, valves and pumps, medical and dental equipment, high-speed automated precision machinery, hardware, business machines, robotics, optical and laser equipment, silicon wafer processing equipment, and semiconductor manufacturing equipment.
Ben Galmiche performing part inspection at O’Fallon Casting |
Prototyping the housing for an integrated wing-tip light of the Boeing 787 Dreamliner |
One area of growth for the company has been in its rapid prototyping operation. It uses expendable patterns generated from a 3-D model from a CAD file to quickly and cost effectively produce a part and verify its design prior to building production tooling.
“In recent years, there have been many improvements in the quality of pattern surface finishes, pattern accuracy, and pattern material alternatives, and today’s patterns are more user-friendly to the near net shapes offered by the investment casting process,” says Ben Galmiche, O’Fallon Casting quality engineer. Because of these improvements, rapid prototyping of cast parts is a good value for customers who want to reduce overall tooling costs and introduce products into the marketplace quickly. Quality inspection is a crucial aspect of the casting business.
“In the past, we didn’t have an effective and efficient way of inspecting solid models," says Galmiche. "We had an old cantilever-type coordinate measuring machine and used a touch trigger probe to collect dimensional data. This process was slow and we were looking for a new alternative.”
For decades, the use of traditional touch probes on CMMs has been the gold standard. However, the time-consuming process becomes an even bigger drain on a quality department’s valuable resources. Metrology engineers are charged with increasingly complex free-form part surfaces that take an exceptionally longer time to thoroughly inspect.
To help enhance the turnaround time of its rapid prototype inspection process, O’Fallon Casting turned to 3-D scanning and point cloud-based inspection. O’Fallon Casting replaced the older CMM with a Global CMM from Hexagon Metrology and equipped it with a Nikon Metrology Cross Scanner, a high-speed, multistripe 3-D laser scanner designed for inspecting part features that provides optimal point distribution in all directions. This new 3-D measurement system was delivered with the PolyWorks 3-D metrology software suite from InnovMetric Inc. that offers a wide array of point cloud engineering tools for quality control and inspection.
Example of an integrated wing- tip light |
Nikon Metrology’s Cross Scanner acquired the entire geometry of the wing-tip light housing. |
This investment proved to be the right move, one that paid off quickly, particularly when O’Fallon Casting received a request in 2008 to inspect the housing for an integrated wing-tip light of the Boeing 787 Dreamliner. Here’s how O’Fallon successfully integrated the point cloud-based analysis in all phases of its rapid prototyping process:
1. A pattern of the wing-tip light housing was created from the customer’s 3-D CAD model of the part using stereo lithography (SLA) and selective laser sintering (SLS).
2. The pattern was then visually and manually inspected to determine if it conformed to the reference CAD model of the part and if it was properly proportioned to account for shrinkage.
3. Once the pattern was verified and approved through Nikon Metrology 3-D scanning and PolyWorks inspection, O’Fallon Casting built a ceramic shell around the rapid prototype pattern.
4. The ceramic shell with the pattern went through a burn-out process, where the pattern was vaporized to leave only the ceramic mold. The part was cast from A356 aluminum that was artificially aged to the T6 condition.
5. The part was then measured using the Global CMM and the laser scanner. The point cloud data gathered during this routine was transferred to the PolyWorks software electronically via the company’s internal network.
In the overall process, O’Fallon Casting used 3-D digitizing and PolyWorks to inspect both the foam pattern and its inherent aluminum part. When gathering dimensional data on these prototype parts, O’Fallon Casting uses a very slow scanning speed to assure that a high level of feature detail is captured. In the process, excess data is collected to capture free-form surfaces and accurately characterize 3-D features, which are essential in increasing the quality of the final product. As the Nikon Metrology scanner sweeps lasers in three directions, the entire geometry of features is captured consistently, regardless of the scanning direction. This allows PolyWorks software to extract features through hundreds of points, rather than relying on a handful of tactile inspection points. Simplified scanner motion paths also mean more straightforward off-line CMM programming. This also compares favorably with tactile inspection where elaborate programming effort is required to define a rather lengthy sequence of touch sensor movements and measurements.
O’Fallon Casting performed efficient scan alignment and overlap reduction using PolyWorks’ IMAlign module. |
“The Cross Scanner and Focus Inspection software from Nikon Metrology is a powerful package,” notes Galmiche. “In less than one week we were up and running to use 3-D scanning in real customer projects. The noncontact scanning solution offers the tremendous advantage of gathering complete data sets, better than what we have ever been able to accomplish through tactile inspection. Likewise, we now perform a laser scanning job in less than a day whereas it previously took us nearly one week. We have reached the point where laser scanning is used in virtually all our rapid prototyping projects, paying off big time both for inspection and troubleshooting purposes.”
“We import the dimensional data into PolyWorks software’s IMAlign module where the partial scans are automatically aligned using a best-fit algorithm to create a point cloud model of the part,” Galmiche says. “At this point, we study the model carefully to determine if we have all of the data we need to make an accurate comparison between it and the customer’s CAD model. If necessary, we will reorient the part on the CMM and gather dimensional data from another view. We use the IMAlign reduce overlap function to automatically remove the excess in areas of scan overlap and create a single set of data points that precisely defines the dimensions of the part in these areas.”
Next, the aligned scans were merged using PolyWorks’ IMMerge module to create a highly accurate, finely detailed polygonal mesh model of the digitized parts.
A color map showing the global comparison between the digitized points and their CAD reference |
Wall thickness, clearance, 3-D angle, and flatness analyses are performed using PolyWorks IMInspect. |
The polygonal mesh model was then exported to PolyWorks IMInspect module for the actual dimensional inspection process. This package uses powerful data-to-CAD alignment techniques including constrained best-fit, and techniques based on features and reference points. For this specific project, a global comparison was performed by calculating the deviation between each digitized point and its corresponding CAD reference. A color map was displayed according to the tolerances set by O’Fallon Casting. IMInspect includes comparison and measurement tools for a complete analysis of surface and cross-sectional deviations, feature dimensions, and GD&T controls, clearance, and thickness. O’Fallon Casting measured the clearance of the part by comparing 3-D distances between two planes to ensure that the ray of light is projected without interference.
“Using simple IMInspect tools, we can quickly see where a part is out of tolerance relative to the customer’s CAD model,” Galmiche says. “Because of the flexibility of the software, we can compare the models using different alignment methods, something that many of our customers find very helpful.”
Using the report generation function of the PolyWorks software, Galmiche prepared an inspection report using the AS9102 format. “In addition to the data, we include snapshots of the model comparison so that customers can quickly see where the part is out of tolerance. We can also illustrate where the part is just a small amount out of tolerance or greatly so by using different colors to indicate different tolerance ranges. Finally, thanks to the PolyWorks IMView free viewer software, our customers can visualize their inspection projects in 3-D from their own workstation.”
O’Fallon Casting also uses the CMM/laser scanner/PolyWorks software combination to inspect its own molds and compression-straightening tooling to ensure that it conforms to design. The PolyWorks/Inspector package quickly shows precisely where tooling may be worn or slightly out of tolerance.
The combination of the Global CMM, Nikon Metrology laser scanner, and PolyWorks software has significantly reduced the time it takes to turn around a rapid prototype part at O’Fallon Casting. “Globally, we are very satisfied with this new point cloud-based inspection process,” says Galmiche. “For a typical part, we can gather the dimensional data we need in about one day and we can perform the data analysis using the PolyWorks software in less than half a day. That is a reduction of about 50 percent in the amount of time the process took in the past. The visualization of the data also makes it faster for customers to review the inspection report and understand the implications of the dimensional data analysis. Also on the expenses side we benefit a great deal. By systematically gaining more profound insight, we are able to reduce the number of prototyping rounds, which saves tremendously on resources and throughput time. And if our old CMM was not to be replaced, our capital investment would have been limited to installing the scanner on any existing CMM system, regardless of the brand.”
