Resources
Back Issues
by Dick Mierzejewski
Glossary of Air Gaging Terms
Amplifier--the readout of an air gage system. An amplifier is a device containing the necessary restrictions to change the pneumatic pressure or flow. It displays readings on a scale as dimensional values. When connected to air gage tooling, readings are amplified many times, allowing the user to easily read the size being measured.
Balance--the resultant nonmovement on the display of an air amplifier that occurs when one nozzle of a two-nozzle tool is closed toward the workpiece and the other nozzle equally compensates for that movement
Column--an air-electronic amplifier or a flow system amplifier featuring a vertical bar graph display or flowmeter tube
CTS--air tooling designed to measure close-to-shoulder, such as an air plug used to measure counterbores. Removal of front-center post on air plugs below 2.510 in. becomes a blind-hole design.
Flowmeter tube--a graduated glass tube of a precise size with a “floating” cork that displays the readings on a flow air gage system. Different size tubes are necessary to accommodate all air gaging applications.
Full scale value--the numeric equivalent of the graduated display. FSV is usually 1.5 to 2 times greater than the tolerance being measured to show approach or oversize conditions.
Magnification--the visual increase of size that is created by an air amplifier. In systems in which the air amplifier has adjustable magnification, this is accomplished by adjusting the flow or back-pressure within the amplifier to agree with the master sizes. On systems that have an air amplifier with fixed magnification, it’s essential that the air gage tooling is precise for full amplification to be achieved.
Nozzle--the orifice in the air gage tooling that emits the air that blows against the part being measured. The diameter size of the nozzle is dictated by the air gage system used. The quantity and location of nozzles are determined by the measurement application.
Nozzle drop--the engineered distance that a nozzle is recessed below the surface of the air gage tool. Nozzle drop is governed by the air gage system. A deeper nozzle drop can provide longer wear life of the air gage tool.
Resolution--the smallest increment on the full-scale display of the amplifier
Restriction--a device used to control air pressure or flow within an air gage amplifier. This may be done with a fixed orifice of a precise size, with adjustable needle valves or with both.
Zero--the process of positioning the magnified spread on an amplifier to a desired relative position on the scale. Zero is generally at midpoint of the full scale, but the spread may be positioned anywhere.
Zero size--the desired midpoint or nominal size of the feature being measured as it relates to the scale. On back-pressure systems, zero is usually the midpoint between the minimum and maximum allowable size. On the flow system, zero is generally the minimum size.
In the competitive world of manufacturing, many companies are looking to increase quality and productivity while reducing frivolous expenses. Some have set their sights on noncontact measurement as a means of saving valuable resources. One such type of measurement is air gaging, a method of precise comparative dimensional measurement that offers users the advantages of improved workflow, increased productivity and decreased downtime.
As this article explains, air gaging is ideal for measuring dimensions with tolerances smaller than 0.005 in. When gaging tight tolerances, resolutions as small as 0.000002 in. can be achieved. Its noncontact characteristic makes air gaging particularly useful for checking soft, highly polished, thin-walled or other delicate materials.
Air gaging’s benefits
Chief among the benefits of air gaging is its ease-of-use, which helps produce accurate results even when performed by unskilled employees. Operation is as simple as presenting a tool to a workpiece and observing the reading. Speed is another benefit: A row of multiple-column amplifiers can be scanned in one glance, reducing time and fatigue. Moreover, relationships (e.g., squareness) that cannot be checked by fixed-limit gaging--and are costly to do by other means--are easily measured with air gaging.
Air gaging is also economical. Once the basic system is purchased, relatively inexpensive additional tooling can be used for a wide variety of applications. Air gages effectively measure all common types of dimensions and are particularly suited for measuring dimensional relationships and match gaging.
Most air gaging systems operate at air pressures that can purge workpieces of contaminants (e.g., abrasive particles, coolant, etc.) at the measurement point, eliminating the need for separate cleaning in most operations. And, because air gage tooling has no moving parts, it’s virtually immune to fouling. Air gaging offers a wide choice of tooling for single or multiple measurement applications, and when repair is needed, air tools are simple to fix.
A brief examination of the fundamentals of air gaging will illustrate the basic premise of air gaging and its evolution into today’s manufacturing environment.
How does it work?
To achieve its precise dimensional measurement, air gaging relies on a law of physics that states flow and pressure are directly proportionate to clearance and react inversely to each other.
The regulated air flows through the restriction (e.g., a needle valve or jeweled orifice) and then through the nozzle. When the nozzle is open to the atmosphere, there is maximum flow through it with minimal pressure--called “back pressure”--between the restriction and the nozzle.
As an obstruction is brought closer to the front of the nozzle, air flow from the nozzle diminishes, and back-pressure builds. When the nozzle is completely obstructed, air flow is zero and back-pressure reaches the pressure of the regulated air supply. During this example, air flow moves from maximum to minimum, whereas back-pressure moves in the opposite direction: minimum to maximum.
These values can each be plotted against the nozzle’s clearance from the obstruction. Except for the extremes of both back-pressure and flow, the curves are straight lines, representing the linear proportions that establish the basis for all air gaging.
Thus, measured decreases in flow provide an accurate correlation between the distance of the nozzles in the air gage tool and the obstruction (i.e., the surface of the workpiece being measured). Similarly, increases in back-pressure indicate less distance between the tooling nozzles and the workpiece.
Although the concept of air gaging may be new to some, the technique itself has been around for decades.
A brief history
Air gaging is a proven technology that has been refined for more than half a century. The first back-pressure air gages were developed in France before World War II by a carburetor manufacturer seeking a method of gaging its carburetor jets.
The company relied on one of the simplest air regulators ever developed. The first restriction suitably reduced the air pressure, and an open-ended tube from a “T” in the air line was submerged in water. Any air contributing to pressure in excess of the pressure at the depth of water bubbled out the bottom of the tube.
The water column also rose in the indicator tube fed from its bottom, and a second restriction before the “T” in the air line between the top of the indicator tube and the air plug provided zeroing control. As back-pressure affected the level of water in the tube, distance between the air plug nozzles and the workpiece wall was indicated.
In 1943, a patent was issued for the simple system--the basis of today’s back-pressure air gages. One of its important features was the use of the newly developed pressure regulator, which eliminated the evaporation problem of the first system. Also noteworthy is its direct indication of dimensional deviations by means of a dial readout. At about the same time, another company developed a system for measuring the flow variation rather than the back-pressure.
Improvements in air gaging systems continue to the present, adding back-pressure bleed and back-pressure differential systems to the roster of simple back-pressure and flow technologies. This article examines all four contemporary systems, as well as today’s enhancement of measurement precision, flexibility, speed and usefulness through amplifier technology.
Reaching the next level
Air-electronic amplification and data collection/processing have raised the resolution of air gaging to the level of millionths of an inch while providing output of measurement data for statistical process control.
Four general types of air gaging systems are in use today: back-pressure bleed, back-pressure, differential and flow. Each has definitive characteristics that affect its diversity of application, accuracy, efficiency and ability to compensate for degradations of associated tooling.
Versatile back-pressure bleed
The “bleed” feature in this configuration accomplishes the back-pressure bleed system’s greatest benefit--its versatility. Tooling for different air gaging systems may be used with the back-pressure bleed.
The back-pressure bleed system is configured with a fixed regulator to control incoming air pressure for maximum linearity. Key to this system’s uniqueness is the important addition of a second adjustable restriction in the feed line opposite the output leg. This second restriction allows users to adjust for different air gage tooling, as illustrated below.
Back-Pressure Bleed System
The system’s magnification is controlled by the typical adjustable restriction between the regulator and air tool. The second adjustable restriction releases excess air into the atmosphere to adjust the zero position. Two setting masters--minimum and maximum--are used to calibrate the system, defining and displaying both ends of the tolerance range for accurate reading of workpiece deviation.
Single-master systems indicate only nominal conformance at the zero point. The back-pressure bleed system defines the tolerance range and explicitly indicates the location of any workpiece in that range. No bad part ever passes.
These systems can also compensate for gradual tool wear or variations in tooling sensitivity and allow the use of different nozzle sizes without losing full amplification.
Back-pressure bleed systems operate at generally higher air pressures than other systems, permitting greater nozzle drop. Nozzles are more protected against wear and damage that can affect measurement accuracy. The higher air pressure also offers better self-cleaning properties.
This system is capable of the broadest magnification adjustment. It accommodates almost any size nozzle, as large as 0.093 in. or as small as 0.020 in. This is especially beneficial when small nozzles are required to check narrow lands.
Back-pressure for limited range
Remove the second adjustable restriction from the back-pressure bleed system, and you get a back-pressure system. This two-master system operates just as the back-pressure bleed without the tooling versatility. The back-pressure system requires dedicated tooling and amplifiers with limited ranges.
Back-Pressure System
Differential: a balanced option
In a differential system, sometimes referred to as a “balanced” system, the air stream is divided and flows through two fixed restrictions, as illustrated below. One side of the system, the bleed leg, ends in a zero valve that balances pressure to the fixed second leg of the system, terminating at the air plug. The difference between these two legs is measured by means of the differential pressure meter, which bridges the two legs.
The differential system is set to zero using a single master for each tooling configuration, making setup somewhat faster. However, the differential system amplifier can only be set to zero. Damaged or worn tooling could result in inaccurate readings. Additionally, with a single-master system, the entire amplifier must be calibrated--rather than just the masters, as in two-master systems.
Tooling for the back-pressure differential system must be ordered for each magnification. Because the single-master system has fixed magnification, worn, damaged or fouled tooling must be returned to the manufacturer for service. Another drawback of this system is that each amplifier only accommodates one full-scale value. If an application requires the measurement of different tolerances, several amplifiers may be necessary.
Simple yet effective flow
The air flow method is measured and read in a flowmeter tube that supports a float. It’s a two-master system with magnification and zero position set by two adjustable restrictions, as illustrated on page 35. As such, the flow system provides accuracy in reporting workpiece deviations within tolerance, similar to the back-pressure bleed system. The range of magnification is augmented by changing flow tubes and scales rather than by a simple adjustment.
Flow gages, by their nature, require a greater volume of air to generate movement of the float. This requires tooling with larger nozzles, which must be kept closer to the part by designing them with a shallower nozzle drop. Shallow nozzle drops can shorten tool life. Also, when measuring smaller workpieces necessitates smaller air plugs and smaller nozzles, it’s difficult to get full amplification.
To its credit, the flow system can be used with long hoses without affecting the response time of the amplifier. This feature makes the flow system ideal for checking long holes, such as gun barrels or oil drill bushings.
A host of choices
The variety of air gaging methods offer users both the benefits of noncontact measurement and a number of choices depending on the specific applications. Each option’s ease-of-use will come in handy during high-yield production schedules, and their accuracy won’t compromise your organization’s quality efforts. When seeking a noncontact means of metrology, air gaging could be the answer to your quality measurement questions.
Dick Mierzejewski is manager of sales engineering at Edmunds Gages. He has more than 30 years of engineering experience in the field of metrology, specializing in air and electronic gaging, automation and custom vision systems. He can be contacted at rmierz@edmundsgages.com.
