Inside Metrology
  |  03/17/2010
Automating Hardness Testing for 100% Inspection
Powder metal component manufacturer uses eddy-current hardness testing for faster throughput.
The powder metallurgy (PM) process offers manufacturers the ability to produce high volumes of complex parts in a cost effective manner. Many powder metallurgy components go through heat-treat processes producing parts with increased strength or wear resistance. To ensure the quality of the heat treat process, powder metallurgy components are traditionally tested using static indentation tests, such as Rockwell and Vickers hardness tests. Such tests, however, are time consuming, subject to human interpretation, and damage the part to some degree. That’s why one major powder metallurgy fuel-pump gear manufacturer has integrated an automated eddy current testing solution into their production line to test 100 percent of their components for proper heat treat conditions.
Situation
The fuel pump component manufacturer required an in-line solution to provide test results as accurate as those from Rockwell hardness testers when inspecting 100 percent of their powder metallurgy rings and stars. The system had to provide 100-percent inspection and accommodate the hardness inspection of two lines simultaneously, measuring 15 star sizes, 10 ring sizes, and three lobe geometries for each size. The test had to be easy to configure with a minimum of setup changes. The overall goal was to reduce both warranty and scrap costs.
Solution
Eddy current testing has been widely used with traditional metal components to verify heat-treat conditions, confirm proper case depth, and verify alloy content, in addition to finding component flaws and defects. At this company, a compact eddy-current testing system from Criterion NDT was installed directly downstream of the heat-treat furnace. The system consists of a multi-channel, multi-frequency eddy current instrument, two eddy current hardness testing coils (one for stars and one for rings), and two sorting stations (one per lane). This provides 100-percent component testing for up to 60 parts per minute with the ability to physically reject out-of-tolerance components.
Two tests were conducted to develop a correlation between a measured Rockwell hardness (HrB) and the eddy-current hardness values. First, 38 sets of 10 samples (380 samples) were tested with eddy current. Next, all 380 samples were sent through a normal Rockwell hardness tester. The eddy current hardness values and actual Rockwell hardness readings are compared in figure 1. Also tested were 22 suspect and failure specimens.
Figure 1: Comparison of Rockwell hardness values to eddy-current hardness values
From this initial test, the correlation between Rockwell hardness and eddy current hardness was very good, showing only about 1 to 3 HrB points variation. Eddy current readings (solid blue line) tended to show a more consistent value when compared to the Rockwell readings. This was readily shown with the results from a sample production test. During this test, nearly 35,000 samples were tested with eddy current. Random samples were taken and had Rockwell hardness checks completed to verify the results. The eddy current coils inspect more of the component’s surface area to compute a more accurate result. The Rockwell hardness readings were only accurate to ±1.0 HrB while the eddy current testing provided more consistent results.
Benefits
The eddy current testing solution allowed the powder metallurgy manufacturer to achieve their quality inspection goals while maintaining production throughput and reducing labor. Because the eddy current instrument captures and stores all of the testing data, it could allow them to identify manufacturing problems, helping with their continuous improvement processes.
Caveats for Eddy Current Automating Hardness Testing
While I am sure this method is a good way to do high production hardness tests in a cost effective manner, any user should be aware of the following;
Eddy current testing used here is a process control method. This is not a HRB(W) Rockwell test as defined by ASTM E18 in indentation hardness testing. It is a comparison test. In all cases of comparison tests, the user must ensure that both tests correlate well. This correlation may or may not be true on two different materials tested. In this case with the powder metallurgy, both Eddy Current and HRB(W) tests must be conducted prior to production for that particular product.
The chart does show good correlation though I am not sure the Eddy Current is more accurate or consistent, since it is not the same test. The sensitivity of movement can be different on other methods and scales.
Most parts have a product specification. If a part must be certified to a particular test ( in this case HRB(W)), all parties should be aware when an alternate or comparable test is done such as Eddy Current. Documentation can be done to demonstrate reliable results. It is probably more important that the Eddy Current test ensures that process is good and that the part will not fail in use.
Automated Hardness (Material Structure) Verification
I concur with the previous statement. Eddy current testing is a "non-destructive" comparison inspection method and should be used in conjunction with traditional Rockwell tests for heat treatment verification. It is an augmentation to the quality control process by providing a method to evaluate 100% of the products manufactured "in-line".
When properly setup, eddy current is very sensitive to material structure variations resulting from heat treat process disruptions. This can dramatically reduce the risk of having a large quarantine issue with products that are found to be suspect using Rockwell testing, by detecting and physically sorting them out immediately.
In addition to improving shipped product quality, eddy current testing can provide a real cost savings in both time and money by reducing the amount of scrap product typically generated with traditional destructive inspection methods, especially in facilities with high volume manufacturing.
