Inside Standards
Denise Robitaille  |  06/07/2005
Denise Robitaille’s picture
Selling the Benefits of Preventive Action
Demonstrate its benefits to top management and you have your sales pitch.
Perhaps one of the hardest persisting sells for the average quality professional is the challenge of effectively communicating the benefits of preventive action to senior management. The sales pitch is twofold: 1) defining the concept and 2) providing concrete examples that are applicable to the organization.Basically, preventive action is the way we manage the consequences of change. It really doesn’t matter if we have initiated the change or if we’re responding to one emanating from an external agent; the elemental attributes of change always apply. Change is inevitable—and it usually carries consequences, which may relate to the actions we take or to our decision to take no action.
Preventive action is an acknowledgement of the inevitability of change and a resolution to establish mechanisms for anticipating change to mitigate negative effects that may ensue.
We know that without appropriate vigilance, things can go awry. We monitor machines, double-check calculations, inspect outgoing product and do refresher training on safety protocols. We also know that obsessive over-inspection and second-guessing is a costly counter-productive squandering of finite resources. The same premise underlies all processes. We need to have adequate definition and control, without which we’d have chaos. For preventive actions, that chaotic state would be exemplified by haphazard attempts to anticipate any or all possible problems, without criteria or defined scope. The enormity of the task dooms it to failure from the onset. A program that purported to encompass counter-measures for all imaginable contingencies would collapse under its own weight.
The challenge is to establish processes that address the most critical and likely risks. These processes may be incorporated into larger processes. For example, FMEA (failure modes and effects analysis) is a step within the much larger design and development process. The overriding question that summarizes the intent of FMEA is, “If we change a feature of this product (for example, the speed of a conveyor), what will happen?” Possible problems might be that objects will fall off the conveyor or items will be deposited too quickly into the next machine. If we really want the conveyor to go faster, we should study how we can eliminate these two potential problems. FMEA is one of the most highly structured and effective preventive action processes for managing design of product and development of manufacturing processes.
One of the less visible, but equally effective tools is related to planning. As part of any plan we need to routinely ask, “What could go wrong?” I like the following example for top management because it illustrates how something wonderful can turn into a nightmare if the fundamentals of preventive action aren’t applied.
The situation: The company has just landed a major contract that will increase annual sales by 30 percent—a definite change for the better. Now, what could go wrong? Well…
  • We might not have the production capacity to handle the orders.
  • We might not have enough trained personnel.
  • Our suppliers might not be able to handle our raw material requirements.
  • We might not be able to respond as quickly to our other customers.
  • We might not be able to deliver on time.
  • We could lose customers.
  • Our reputation in the marketplace could be damaged.
The initial step in this kind of preventive action should be to establish a defined process that kicks in whenever the organization bids on a contract that exceeds a pre-determined value. The process should require the organization to assess the risks associated with accepting the contract. The next steps should be to determine the appropriate action (whether to accept the order) and the next to implement the action.
Using this particular example has the added benefit of connecting the preventive action to the bottom line. Management must assess processes and related resources to handle the risks engendered by this new contract, so that they may allocate the requisite monies to ensure the desired outcome. That means they need to access information derived from such management system features as:
  • Analysis of process capabilities
  • Records of employee training and qualification
  • Evaluation of supplier performance and capacity
  • Review of customer feedback
  • Calculation of ROI
The outcome of the deliberations will result in a plan of action based on the risks weighed against the constraints. The action may involve adding a third shift, forming a strategic alliance with key suppliers, outsourcing a process that can best be done by an outside contractor or any number of other initiatives.
The final step is close out. This will occur long after the action has been taken. A review is done to determine if the results conform to the desire outcome.
  • Were we able to satisfy the customer’s requirements?
  • Did the additional resources that were allocated improve the bottom line?
  • Did we realize any additional benefit from the investment?
The output of the review should demonstrate to top management the financial benefits of a well controlled preventive action process—the sales pitch quality professionals need to keep the program going.
Denise Robitaille
Denise E. Robitaille, principal of Robitaille Associates, is committed to making your quality system meaningful. Through training, Robitaille helps you turn audits, corrective actions, management reviews, and processes of implementing ISO 9001 into value-added features of your company. She’s an RABQSA-certified lead assessor, ASQ-certified quality auditor, ASQ Fellow, and a member of the U.S. TAG to ISO/TC 176, the committee responsible for updating the ISO 9000 family of standards. She’s the author of numerous articles and several books, including The Corrective Action Handbook and The Preventive Action Handbook, and a co-author of The Insider’s Guide to ISO 9001:2008, all published by Paton Professional.
