How did your quality system get so complex and redundant?
Many companies established their quality systems after having purchased a software program with a “canned” quality manual and procedures. Software companies try to subliminally sell you the concept “more is better.” Purchasing companies often don’t realize they also purchase a lot of junk that adds unnecessary complexity and length to their documentation system.
Other companies employ a management representative who over-interprets the standard so much that he or she develops a quality system that is too complex. Perhaps this is the result of management representatives being so fearful of missing something that they document everything, including how to fill the kitchen sink.
Many more efforts aren’t well-coordinated, with documents written in each department separately, while ignoring the big picture of the system approach. The result is several documents addressing the same issues (i.e. nonconforming product, identification of product, etc.) and tons of redundancy.
Other people who put your quality system together (including consultants):
What’s wrong with an overly complex and redundant system?
The disadvantages of an overly complex and redundant quality system are:
How to eliminate the “junk” from a quality system?
In assisting companies with converting their ISO 9000:1994-registered quality system to one based on ISO 9001:2000 requirements and now, once again, assisting automotive suppliers in their efforts to convert to ISO/TS 16949, I challenged them to decrease their words and documents by at least 50 percent. So far, all companies have been extremely receptive to doing so. They realize their system is too complex and cumbersome for effective implementation. The quality system should speed up the effectiveness of their operations, not slow it down.
As an example, in two cases thus far, we were able to reduce the length of a document control procedure from eight pages to two pages without eliminating content. We were able to do this by simply eliminating the junk from the procedures.
How can your company do this? In the spirit of lean operations, simply tear apart the procedure format and eliminate what isn’t adding value to the document. You can determine whether or not the words in a document or the document itself add value by asking:
In my experience, the biggest failure in lean documentation is the existence of redundant statements (multiple statements that basically state the same requirement). Are documents, primarily procedures, really necessary? In trying to comply with ISO 9000:1994, many companies felt they needed procedures for each of the 20 clauses. This was an incorrect assumption. Each company was supposed to ensure that each of the requirements was addressed in a procedure, not necessarily have a separate procedure for each clause. Some questions you can ask yourself regarding your documentation system might include:
To illustrate the points above, the following sections of a typical procedure may not add value and can probably be eliminated:
Also, dividing up a procedure by listing responsibilities by function or title doesn’t allow for describing your process as a flow from one action to the next, as required by ISO 9001:2000. The “responsibilities” section should be eliminated and included in the body of the procedure so the procedure can flow from one step and person/department to the next.
The following recommendations are what I would suggest for inclusion in your lean procedure format:
Recommended procedures sections
For a procedure, it’s recommended to only include the purpose, scope, procedure (which consists of responsibility and action), and revision record.
1. Purpose: This section should explain why the procedure exists. Often, the purpose of the procedure is written right in the standard. As an example, the purpose of the internal audit procedure is written in the first paragraph of Section 8.2.2 of ISO 9001:2000. It shouldn’t be written as, “The purpose of this procedure is to define the responsibilities and requirements for planning and conducting audits, in addition to reporting audit results and maintenance of the records.” This explains “what” is in the procedure, not “why” the procedure exists.
2. Scope: This section is often misunderstood, as is evidenced by the same statement written over and over again in each procedure. An example is, “This procedure applies to all operations in the ABC Company.” Remember, if a statement is repeated more than once, it isn’t adding value. The “Scope” statement should be broken into two sections, the “Breadth” and the “Depth.”
2.1 Breadth: The key words include “from” and “to” as in the example below. If possible, this statement should reference procedures as in “From the completion of the ___________ procedure to the beginning of the _____________ procedure.” This will also help your company comply with the ISO 9001:2000 requirement in section 4.1b, which states that your organization shall “determine the sequence and interaction of these processes.” Each procedure’s “Breadth” statement will then be aligned with the overall process flow perhaps depicted as an overall process flow diagram in section 4.1 of the quality manual.
2.2 Depth: The key words in this section are “Applies to,” as in the text box example. In this section, you should list every product, service, department or document this procedure applies to.
3. Procedure: I recommend dividing this section into two sections (columns) as shown in the text box example. The first section (column) is the “Responsibility” section, which forces the writer to identify “who” is responsible for each paragraph.
The second section (column) is the action that occurs. This section should always start with a verb or a participle phrase (i.e., an “if” or “when” phrase followed by a verb). See text box example.
4. Revision Record: This section should include “what” or “where” the change occurred, the new revision and the approvals, much like a print has a revision history.
Characteristics of a well-written procedure
A procedure should explain “who” does “what” and, if applicable, “when” and “where.”
The following recommendations will allow for an efficient, effective, nonredundant and useful procedure.
Although there may be a few exceptions, most procedures shouldn’t exceed three pages. The actual procedure should start on the first page, not on the second or third. There should never be any redundancy of statements made within a procedure or between procedures and/or work instructions.
Procedures should refer to other documents or forms within the body of the procedure.
Don’t describe how to fill out a form (i.e., “Where it states “date,” record today’s date”). Just write “fill out the form completely” or “complete section I of the form.” Make your forms self-explanatory and if necessary, insert examples. An example of this for a corrective action form might be: “Verification (i.e. review documents, training records and visually verify the action is working.)”
Procedures shouldn’t have forms attached to them. Forms are stand-alone documents.
Procedures should contain electronic linkages to other documents, so that, if necessary, the user is only a click away from reading them.
Recommended work instructions sections
For a work instruction, it’s recommended to include just the action and revision record. A work instruction should only describe how a procedural step is performed by one job title (i.e. inspector, engineer, customer service representative).
Action: Start with a verb. There’s no need to state responsibility since it’s already been stated in the procedure that’s referring to the work instruction. If you’re trying to write a work instruction and there are different people responsible for different tasks, then this document, or a portion of it, should be in a procedure.
Revision record: Same as a procedure.
Recommended approvals: There should be a purpose for each approval type (i.e. management representative, manager) and it should be stated in the document control procedure. The following excerpt is an example of this requirement:
3. Procedure
| 3.1 Responsibility | 3.2 Action |
Any Employee | 1. Initiates the change or addition of a document (quality manual section, procedure, work instruction or form) by submitting a draft or marked-up copy to the management representative using the existing format of comparable documents. |
Management Representative | 2. Reviews the document for initial approval and advises the employee of changes to be made. Reviews the document to ensure:
If acceptable, initiates the process of changing and/or adding to the document. |
By describing the management representative’s responsibility as such, you are fighting entropy, or the law of disorder, which states that everything proceeds toward disorder. Quality systems have a tendency to grow out of control. This will help to maintain system control.
Case study
The following table illustrates the results of adhering to the guidelines defined above. This case study involved the conversion of a warehousing and distribution company’s quality system from ISO 9002:1994 to ISO 9001:2001. The same results occur when converting a QS-9000 system to ISO/TS 16949.
The reduction of the number of documents and pages in the remaining documents didn’t involve a reduction in content. In fact, the content was actually increased. Also, font size and type didn’t change.
| Topic | Measure | Before | After | Reduction |
Quality manual | Number of pages | 43 | 31 | 28% |
Procedures | Number of procedures | 20 | 10 + 1 customer satisfaction | 50% (32 pages eliminated) |
Procedures | Total number of pages | 80 | 25, including customer satisfaction | 69% |
Conclusion
This is the perfect time to downsize your documentation system (especially automotive suppliers) and make it more user-friendly. Your company has been registered for some time now and many of the employees know the deficiencies and complexities of your system. In the spirit of continual improvement, it’s wise for companies to take advantage of making their quality system more user-friendly by improving and downsizing it now, and putting controls in place so that it does not get out of hand again.
Use this sample meeting format to improve your QMS:
Management review meeting
(Note: If this type of information is already contained in 5.6 of your quality manual, then keep it there and don’t have a procedure like this that basically states the same requirements.)
Purpose: To define our system of reviewing the continued suitability, adequacy and effectiveness of our QMS, to ensure that the resources needed to achieve the quality objectives are identified and planned, and to assess opportunities for improvement and needed changes to our QMS, quality policy and related objectives.
Scope:
Breadth: From the scheduling of the management review meetings to the publication and distribution of minutes, and the implementation of actions in accordance with our corrective and preventive action procedure (8.5.2-01) and the quality planning procedure (7.1-01).
Depth: This procedure applies to the review of the entire management system including the policy, objectives, procedures, instructions and how well the system is functioning to achieve our stated objectives.
| Figure 1: Procedure | |
Management Rep. (MR): | Schedules the management review meetings to be conducted in January, April, July, and October of every year. |
MR: | Sends out an agenda of the meeting at least two weeks in advance of the scheduled meeting to the management team (as defined in section 5.5 of the quality manual). |
Invitees: | Must either be present for the scheduled meeting or send a representative to the meeting and/or provide the MR with the status of any outstanding actions, data, metrics or information for which he or she is responsible. |
MR or president: | Conducts the meeting and, at a minimum, ensures the following topics are reviewed by the appropriate personnel:
Management: Team: | Initiates the corrective and preventive action procedure (8.5.2-01) based on the review and initiates the quality planning procedure (7.1-01) for new products, projects, processes or systems currently beyond the organization’s capability. |
MR: | Ensures the preparation and distribution of decisions made and actions to be taken on the meeting minutes form (5.6-01A). Retains these minutes in accordance with the control of quality records procedure (4.2.4-01). |
President: | Uses information and data from meeting as input into the quarterly companywide meeting in accordance with the internal communication of system effectiveness work instruction (5.6-01-01). |
Invitees: | Carries out or delegates actions as defined in the meeting and prepares data/information as required for the next meeting. |
| Figure 2: Revision Record | ||||
| Revision Level | Description of Change | Approved By | Approval Date | |
Original | None | MM | 6/30/98 | |
A | Update entire procedure to conform to ISO 9001:2000 | MM | 3/30/xx | |
Sign In to get started!
