Laurel Thoennes  |  07/22/2009
Laurel Thoennes’s default image
QualiPedia: Statistical Process Control (SPC)
Statistical process control might be the most misunderstood approach to quality improvement.
Search the internet for “What is SPC?” and there are many definitions and descriptions of statistical process control that are correct but not complete. They are true but not the whole truth.
From the search results, a general definition and description of SPC could be as follows.
Definition: SPC is the application of statistical tools and techniques to find, analyze, and control variation in processes.
Description:
Find. Monitor, measure, and collect data using tools such as control charts for variables data(i.e., average/range charts, average/standard deviation charts, run tests, etc.) and control charts for attributes data (i.e., c charts, p charts, u charts, etc.)
Analyze. Through descriptive analysis of data and charts (using histograms, Pareto charts, scatter plots, etc.)
Control. Employ techniques for problem solving (brainstorming, critical thinking, using fishbone diagram, flowcharts, etc.) and for process capability (capability ratio—Cr, performance ratio—Pr, capability index—Cp, process capability—CpK, etc.)
With so many ways of obtaining data and attaining knowledge, how could this not be complete answer to What is SPC?
Because SPC is more than learning to use the tools and techniques. The answer falls short in explaining what to do with this knowledge, how to apply and develop the knowledge beyond monitoring processes for corrective actions or maintaining status quo.
“Control charts are effective only to the extent that the organization can use the knowledge. Knowledge gathering is in vain without an organization that can disseminate and use this knowledge," states Donald J. Wheeler. “While it is easy to focus on the tools, and while it is easy to teach the tools, the tools are secondary to the way of thinking. Learn the tools and you will have nothing. You will not know what to do. You will not know how to use the tools effectively. Learn and practice the way of thinking that undergirds the tools and you will begin an unending journey of continual improvement.”
Sources:
http://www.spcpress.com/pdf/DJW129.pdf
http://www.theqcgroup.com/calendar/detail.php?id=23
Laurel Thoennes is managing editor for Quality Digest.
You can create content!
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
