Inside Six Sigma
Mark Crossley  |  01/19/2005
Mark Crossley’s default image
Considering Reliability as an Issue for Six Sigma
Before defining reliability, it’s important to define failure.
When we discuss or mention Six Sigma, we almost always hear about getting defect rates down to 3.4 ppm. Consider a light bulb. How would you like to have a defect rate of 3.4 ppm only to find out that the bulb lasted just 20 hours before it burned out? This isn’t good, even though the Cpk was 1.50. The definition of quality relates to fitness for use, meeting the specification and the life of the product. That is, how long will it satisfy the customers’ needs? That’s reliability.
There are two major quality topics that concern the element of time. They’re statistical process control (SPC), which is how the process performs over time; and reliability, which is how long the product lasts. Reliability is the probability of mission success over a defined period of time, under a defined operating environment. Today it’s possible to substitute the word "cycles" in place of the word "time." But before defining reliability, it’s important to define failure. In the light bulb example, it’s simple: it either lights or it doesn’t. For more complex systems, the definition of failure isn’t as straightforward. What would be the definition of failure for human beings, for example?
The rate at which products fail, λ, is constant within the time period defined as useful life. Early failures generally occur during a period called “infant mortality” and happen because of poor quality workmanship or defective raw materials. The infant-mortality period generally represents a small fraction of the product that wasn’t detected during a burn-in phase. It’s the product within the steady state or constant failure rate that is defined as the useful life of the product.
A model that’s frequently used to predict the reliability of a product while it’s in its useful life is the exponential model:
Where R = the reliability at time t
θ = the mean time before failure (MTBF)
Determining the MTBF of a product in its useful life
Because the failure rate is constant, place a number of units in a testing program and test them until there are failures. Testing can be done until there’s a predetermined amount of time (cycles) of the units or until there’s a predetermined number of failed units. For this discussion, assume that all the units have failed (complete data). By averaging all the times to failure, it’s possible to determine the MTBF.
Consider the following example:
A motor is run to 1,800 rpms under a constant load for one hour. It’s then allowed to cool to 20° C and then run for another hour. When the current draw exceeds a specified number of amps, the motor is defined as having failed.
The number of cycles to failure are given:
53,717
52,900
53,500
50,648
53,195
49,600
51,280
52,293
54,495
53,280
53,100
54,277
54,080
49,928
53,307
The MTBF is given by:
But there’s one major problem. It took more than six years to complete the study. There are other ways to accelerate the test and effectively compress the time to failure. One method is elevating the test temperature, known as the high temperature operating life acceleration model. The devices are subjected to an elevated temperature for the life of the test. It’s assumed that the failure mechanism will follow an Arrhenius relationship. Many failure modes follow this relationship as do chemical processes, diffusion, rates of oxidation, etc.
For life testing where elevated temperatures to accelerate failure are used, the Arrhenius model can be expressed as:
T = the temperature in degrees Kelvin ( 273.16 +° C)
= Boltzmann’s constant, 8.6173 x 10 -5 eV/ ° K
The degree to which an increased temperature will increase the MTBF can be expressed using a temperature acceleration factor,
The life of the product under normal operating temperature is usually much longer than it would be under the higher operating temperature. An acceleration factor of 50 indicates that one hour in the accelerated or stressed condition would be equivalent to 50 hours in the normal use condition.
The MTBF is assumed to be inversely proportional to the temperature. If tests at two different temperatures are done , the times to failure are related to the respective temperatures as follows:
Combining these three equations gives the temperature acceleration factor:
Solving for the activation energy, :
See the following example of determination of the activation energy:
The MTBF at 90° C for the previous motor example is 7,000 cycles and the MTBF at 120° C is 635 hours. The activation energy would be:
Note: the temperature is expressed as degrees Kelvin. Add 273.16 to the degreed Centigrade.
Both the 90° C and 120° C represent a stressed or elevated condition relative to the normal ambient operating temperature of 20° C.
Knowing the activation energy, it’s possible to determine the acceleration factor:
= Boltzmann’s constant, 8.6173 x 10-5 eV/ ° K
TUSE = 20° C ( 293.16 ° K)
TSTRESS = 90° C ( 363.16 ° K)
One cycle at 90° C is equivalent to 7.52 cycles at 20° C.
The MTBF at 20° C = (MTBF @ 90° C)
MTBF @ 20° C = (7.52)(7,000) = 52,640
The same conclusion as with the six-year study was reached but in only 9.6 months.
In all these cases, the MTBF is determined by testing units until failure. Because sample data is used, we are subject to statistical error—as with all statistics generated from samples. MTBFs are estimates of the truth. The following equation is used to calculate the two sided confidence interval for the MTBF, upper > True MTBF > MTBF, lower:
MTBF, upper =
MTBF, lower =
Confidence = 1 – α and α = risk
= total accumulated test cycles or time.
r = total number of failures
Example of the 90% confidence interval for the original motor test data:
Total number of cycles for all units, ta = 789,600
Total number of failed units, r = 15
MTBF, upper =
MTBF, lower =
MTBF, point estimate = 52,640
In spite of not knowing the true MTBF, there’s a 90% confidence that it’s between 36,077 and 85,394 cycles.
There are two ways to reduce this range:
  • Reduce the level of confidence
  • Test more units to increase the total number of failures in the test program.
Of these two, the latter is the better choice.
Selected references
Mark Crossley
Mark Crossley has more than 20 years experience in the quality sciences and provides training on an international basis. He is a senior member of the American Society for Quality and is the author of The Desk Reference of Statistical Quality Methods. His academic and professional credentials include a bachelors degree in chemistry/mathematics and a masters of science in quality assurance from California State University. He holds several certifications from the American Society for Quality, including certified quality engineer, certified reliability engineer, certified quality manager, certified quality auditor and certified Six Sigma Black Belt. He’s also a Master Black Belt. Mark Crossley has been recognized by the ASQ as one of their highest rated instructors, having been awarded the Faculty Excellence Award in 1997 and 1998. He has also presented a wide variety of courses for the ASQ, including quality engineering, design of experiments, statistical process control, and advanced statistical process control. He has achieved the distinguished recognition of certified management consultant by the Institute of Management Consultants.
You can create content!
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
