(Sciemetric Instruments: Ottawa, ON, Canada) -- Sciemetric Instruments Inc. announces the release of the latest version of QualityWorX, its proprietary analytical software which includes an improved web reporting interface that gives all users real-time access to centralized manufacturing data.
This new version includes Web Reporter, an improved web reporting function that makes manufacturing data housed in the centralized QualityWorX database available across the network through a web browser in a user-friendly interface. This simple but powerful interface, accessed through local or wide-area networks, makes manufacturing data available to technicians and managers. The reports provide insight on quality and throughput and enable some drill-down to determine the cause of issues affecting them.
Manufacturers no longer have to gather data from disparate sources and generate time-consuming manual reports for internal quality initiatives or regulatory requirements. With Web Reporter, the pertinent information can be quickly and easily accessed from the QualityWorX database and presented in an easy-to-understand format. An extensive library of standard reports is included in the core software. In just a few clicks, even nontechnical managers can create these powerful reports: First-Time Yield, Summary Report, Trend Browser, Failure Report, Failure Pareto, Repair Traffic and Defect Pareto.
When used with Sciemetric’s sigPOD test stations, the hardware and software combine to create unparalleled visibility into manufacturing processes, and users are able to gain the full value of process signature technology. The methodology—capturing and then analyzing the unique process signatures of critical manufacturing processes—provides complete visibility into manufacturing processes, which lowers failure rates, quickly determines root causes of defects, shortens test-cycle times, and improves manufacturers’ ability to conduct selective, rather than sweeping, recalls. Detailed records of end-to-end manufacturing data prove that products meet internal standards and support regulatory compliance.
QualityWorX can also be connected to third-party test stations and PLC networks. Regardless of the hardware components selected—either the plug-and-play family of sigPOD test stations or proprietary test devices from other vendor—test stations can be added or deactivated in QualityWorX without any production down time. Because the application is based on an SQL database and has been developed using open standards such as XML and OPC, all test devices can take full advantage of the storage and analysis power of QualityWorX.
Web Reporter is now included with every QualityWorX installation at no additional cost.
For more information, visit www.sciemetric.com.
Sign In to get started!
