Inside Metrology
Pinpoint Laser Systems  |  10/27/2009
Pinpoint Laser Systems’s picture
Product News: Pinpoint Laser Systems’ 90-Line Square Plane
Ideal for squaring machinery and equipment, setting up presses, and more
(Pinpoint Laser Systems: Peabody, MA) -- Pinpoint Laser Systems is introducing a new right 90-Line Square Plane. This newest Pinpoint product is ideal for squaring machinery and equipment; setting up presses; checking machine tools; aligning guide rails; establishing parallelism between web rollers, idlers, and take-up reels; and a wide variety of other measuring and alignment tasks. Coupled with the Laser Microgage system, the 90-Line Square Plane allows quick and precise equipment measurement and alignment for optimal production efficiency.
The 90-Line Square Plane is placed into the path of the laser reference beam and forms a precise right angle laser reference beam for checking alignment and taking measurements. The nosepiece of the 90-Line, and the right angle laser beam projected from it, can be turned through a full 360° rotation to define a flat reference plane. This is ideal for checking the squareness and flatness of flanges, press plates, rolls and web handling equipment, machine tools, and many other precision alignment tasks.
The 90-Line Square Plane is machined from a solid block of aluminum and covered with a hard anodized coating for years of reliable use on the factory floor. A fine adjustment knob helps position the laser at long distances and a lock secures the beam in place. The housing for the 90-Line has a variety of tapped mounting holes and machined reference surfaces for added versatility when working with production equipment. The 90 Line Square Plane and the Laser Microgage provide precise measurements accurate to 0.0001 in. (2.5 µm) and can be used over ranges up to 180 feet (55 meters). A digital interface connects directly to a laptop or PC for downloading readings and generating alignment and measuring reports. The Microgage line is highly versatile and can be used for many industrial applications. It is small enough to fit into a compact storage case.
All Pinpoint products are designed and manufactured in the United States and allow industry and manufacturing firms to optimize their equipment and reduce downtime while increasing profits with improved machinery alignment.
For more information visit our web site.
Since 1992, Pinpoint Laser Systems has been manufacturing a broad line of easy-to-use products that incorporate lasers, optics, electronics, and solidly built mechanical features used for routine and complex measuring and alignment tasks. Pinpoint’s measuring equipment is used in aerospace, power generation, machine shops, paper and textile mills, shipbuilding, plastic and film production, electronic assembly, and other industries. Pinpoint works closely with manufacturers to develop and provide custom alignment solutions for robotic applications, medical scanning devices, aircraft assembly, electronic part fabrication and numerous other applications.
