Inside Quality Insider
Business901  |  05/06/2010
Business901’s picture
E-book: Value Stream Marketing
An overview of applying lean principles to the marketing process
(Business901: Fort Wayne, IN) -- Joe Dager, owner of Business901 has just released a 27-page e-book that provides an overview of the value-stream marketing process. The book, Value Stream Marketing, is an overview of applying lean principles to the marketing process. It also serves as an introduction to the Business901 marketing kanban and the value-stream marketing 28-day program.
“Value-stream marketing is not about developing a repeatable process,” says Dager. “Repeatability means doing the same thing in the same way to produce the same results. Though repetition will allow you to convert your inputs to outputs with little variation, it also implies that no new information can be generated and used. Repeatable processes are not effective, because precise results are rarely predictable in the marketing process. Reliable processes focus on outputs, not inputs. Using a reliable process, you can consistently achieve a given goal even though the inputs vary dramatically. Reliability is results driven.
“Marketing cycles are not completely stable. They are subject to variations caused by new knowledge. They are constantly being improved. The emphasis of activities changes during projects from more emphasis on understanding the customer at the beginning to more constructing and testing marketing functions at the end. We are trying to eliminate variation caused by new knowledge. A marketing process that does exactly the same thing every time is useless, but we are trying to eliminate variation that we cause for no good reason,” Dager adds.
The e-book, Value Stream Marketing, can be found on the Business901.com web site.
Business901
Joe Dager’s Business901 is a progressive company providing direction in areas such as lean marketing, product marketing, product launches, and relaunches. The company provides and implements marketing-, project-, and performance-planning methodologies in small businesses. The simplicity of a single flexible model will create clarity for your staff and as a result better execution. Business901’s goal is to allow you spend your time on the need vs. the plan.
