The process approach is a concept crucial to proper quality management. This concept is not new. In fact, it’s how ISO 9001 was designed to work from the very beginning.
A process approach allows businesses to realize the full benefit of a management system by viewing and managing real processes affecting the quality of products and services offered to customers. The more prevalent standard-based approach, as opposed to a process approach, was born of a small misunderstanding that grew larger as a snowball effect overtook the ISO 9000 world. Businesses followed bad examples, and the problem grew larger. Incorrectly applying ISO 9001 requirements became the norm.
The misunderstanding is simple. ISO 9001 was never intended to tell management how to manage. It never purported to contain instructions for how to run a business. It was merely intended to provide auditors with a consistent set of criteria with which to assess quality management systems (QMS). It’s a set of quality principles meted out in specific requirements, intended to provide a basis for consistent, fair assessment. Businesses have applied ISO 9001 in such a fundamentally incorrect manner—focusing on conformity to ISO 9001 instead of focusing on their own quality management—that the purpose, value, and intent of ISO 9001 have been defeated.
The original version of ISO 9001 was very clearly intended as audit criteria. Of course nobody was supposed to write 20 procedures pandering to the 20 elements of the standard and call the resulting mess a QMS. ISO 9001 was not supposed to be implemented as a QMS by management; it was supposed to be applied as audit criteria by auditors. Yet clearly most organizations used it to “implement their QMSs”—evidenced by the same 20 standard-based procedures defining the management systems of thousands and thousands of organizations.
The intended users of ISO 9001—auditors—often promoted the idea that the standard was intended for use by management. “Here, management, these requirements are for you to implement; we’ll check back later to see how well your procedures match,” as opposed to “Here, management, these requirements are what you will be assessed against; we’ll use them to see if your system conforms.” The former urges management to implement ISO 9001; the latter hopes management will implement a system that complies with ISO 9001, or more accurately, they will document the existing system as it is implemented and enhance it as necessary to meet the requirements of ISO 9001.
Incorrectly thinking that they were the intended user of ISO 9001, management developed standard-based systems of 20 procedures to address ISO 9001:1987 and 1994 requirements. Specific requirements were subsumed beneath 20 general elements, while each element called for documented procedures addressing its requirements (thus allowing objective definition appropriate for assessment). A standard-based mindset concludes that the standard required 20 procedures—one for each element—to satisfy the requirements for documented procedures.
A process-based mindset, on the other hand, concludes that documented procedures—whatever their number—must address the requirements of the 20 elements. So, an organization operating 10 processes would document those processes using 10 procedures—one for each process. These 10 procedures would need to appropriately address the requirements of the 20 elements as they apply to the defined 10 processes. So, many were confused about who the implementers of ISO 9001 really were.
Based on user survey results and observations of widespread misuse of the standard, the authors of ISO 9001:2000 recognized organizations were often using the standard to establish their QMSs. So many organizations did this that ISO seemed to accept this new group of unintended customers. “Since that’s how our product is being used,” the thinking seemed to go, “then we must respond to the demands of these unintended, uninformed customers.”
ISO appeared to rise to the occasion and cater to this unintentional audience. The authors of ISO 9001:2000 made a move toward addressing this new audience, and knew they needed to make it clear that the standard is supposed to be applied using a process approach.
Apparently resigned to the fact that management was going to use the standard as a basis for QMS design, the authors did what they could to promote application of a process approach by an audience with a standard-based mindset. The first attempt to stymie a standard-based mindset can be found in ISO 9001:2000 clause 0.1—Introduction, where it is stated that it is not the intent of the standard to compel uniform QMS structure and documentation (i.e., by using it as a foundation for QMS definition).
Then in ISO 9001:2000 clause 0.2—Process approach, the standard explains that PDCA is the basis of the process approach. The supposition is that QMSs will be structured with PDCA in mind, not with the uniform requirements of ISO 9001 in mind. Process-based procedures describe processes as: the proper subject of PDCA application. A process-based procedure represents the plan for processing pursuant to the plan phase of PDCA; a standard-based procedure is merely written in response to an ISO 9001 requirement. Procedures raised in response to ISO 9001 requirements cannot effectively describe the plan for any core business process. By merely describing conformity with individual ISO 9001 requirements, standard-based procedures offer the do, check, and act phases of PDCA no real basis upon which to operate. From an organizational perspective, PDCA operates on processes, not requirements.
In ISO 9001:2000 clause 4.1—General requirements, the standard provides requirements presumed adequate to determine if a defined system demonstrates a process approach. However, the requirements in clause 4.1 were apparently not adequate to overcome the standard-based mindset. Many read the standard to mean that only six procedures were required to define a QMS, since there were now only six requirements expressly calling for documented procedures (basically to cover support processes).
If organizations were going to use the standard to create QMSs, the authors seemed to think that an admonishment against the standard-based approach (clause 0.1), an endorsement of the process approach (clause 0.2), followed by requirements effectively demanding a process approach (clause 4.1) would solve the problem. Clearly that didn’t work.
With ISO 9001:2000, organizations simply took the reduced emphasis on documentation to mean that a QMS needed less documentation—from 20 procedures down to six. However, a good QMS may have been defined by only 10 procedures in the 1994 version, thus already having reduced documentation from that needed by the conventional 20-procedure wisdom. When the standard reduced emphasis on documentation in 2000, a system previously defined by 10 procedures was still defined by 10 procedures. Definition of the system and its processes does not depend on ISO 9001, nor should documentation describing a defined system. No system was ever properly defined by 20 standard-based procedures or merely by the “six mandatory” procedures.
To overcome the standard-based mindset, it seems it was a mistake to allow the inmates to take over the asylum. ISO seems to have shot itself in the foot trying to achieve customer satisfaction—catering to customers who were misapplying the standard. With the release of ISO 9001:2000, it’s as if ISO was saying: “Okay, if you all insist on using this standard for assessing QMSs to establish QMSs, which is actually very cheeky cheating, then we are including a requirement to apply a process approach. So, if an organization uses ISO 9001 as a basis for its QMS, management can’t miss this endorsement of, and requirement to apply, a process approach. (See clauses 0.1, 0.2, and 4.1 et al.) We are reducing the emphasis on documentation to make it more clear that this exercise is not merely about writing voluminous documentation to claim conformity with the individual requirements of the standard, as has been done thus far. Nobody liked that documentation, nor should they have, it was misguided and not required in the first place. So, an ISO 9001-based QMS will be a process-based QMS—documented according to operations, not according to the requirements of ISO 9001.”
What everyone seemed to hear was: “The process approach only requires six procedures, and clause-by-clause procedures are still OK.”
It seems trouble can be expected anytime a simple, organic concept becomes codified and institutionalized. Quality management, when structured, is supposed to be all about PDCA. Simply, PDCA is a way of managing. But when it becomes a discrete requirement couched in technical terms within an international standard (e.g., “process,” “system,” “procedure,” “requirement,”), the risk of misapplying PDCA appears to be greater than many appreciate.
Abridged excerpt from The Process Approach of ISO 9001, by T.D. Nelson (Amazon Digital Services, 2014).
No, not right.
There is so much fundamentally wrong with this piece, it requires serious clarification. I really am at a loss how this stuff gets published by a magazine that has an editorial staff. Much of this represents Mr. Nelson's old arguments which have been largely debunked by other professionals, and yet this gets re-published here without any editing.
So let's look at the facts.
ISO 9001 was NOT "designed to work from the very beginning" under the process approach. The process approach was introduced with the 9001:2000 revision with much fanfare, as the process approach had never been part of ISO 9001 -- nor its precursors of MIL-Q-9858 or NATA AQAP-1, BS9000, BS 5750, BS 5179, ISO 9001:1986 and ISO 9001:1994. Given that Mr. Nelson touts himself a "process approach pro" one would hope he would have a sense of the history that got him there.
Next, Mr. Nelson's idea of what ISO 9001 is for -- and (the most egregious) his view of who it's "users" are -- are grossly incorrect. ISO 9001 was not designed solely for the use by auditors, and auditors are not its user base. This point has been corrected time and time again to Mr. Nelson in other forums, but he sticks to it like glue.
Fixating on a single half-sentence in ISO 9001's scope, Mr. Nelson ignores the entirety of everything else in the standard, and the entirety of everything that ISO itself has ever said about ISO 9001. He has to ignore and contradict the very authors of the document to get to this position. The standard says, ISO 9001 "can be used ... to assess the organization's ability to meet customer, statutory and regulatory requirements applicable to the product, and the organization's own requirements." But Mr. Nelson interprets the word "can" as "shall" and has to strip out every other possible use for the standard to get to his unique, registrar-centric position. He ignores the entire six-point bulleted list that precedes the very sentence he fixates on, which explains some criteria on which to design a QMS.
Mr. Nelson wrongly claims ISO 9001, "never purported to contain instructions for how to run a business. It was merely intended to provide auditors with a consistent set of criteria with which to assess quality management systems" and "ISO 9001 was not supposed to be implemented as a QMS by management; it was supposed to be applied as audit criteria by auditors."
Wrong. So wrong it's mind boggling.
In order to reach this impossible interpretation, Mr. Nelson has to utterly contradict nearly everything ever said by ISO about its own product. In its "ISO 9000 Family of Standards" guide, ISO clearly explains that ISO 9001 is intended to ISO 9001 is be "used when you are seeking to establish a quality management system." It goes on to say ISO 9001 "defines what you should do to consistently provide product that meets customer and applicable statutory and regulatory requirements [and] enhance customer satisfaction."
There are so many quotes from ISO on this, it would be impossible to include them all. Meanwhile, there is not a single quote that claims the standard is intended to be used solely by auditors, for auditing.
Mr. Nelson then goes on to say, "A process-based mindset, on the other hand, concludes that documented procedures—whatever their number—must address the requirements of the 20 elements." As previously debunked on LinkedIn, a "process-based approach" does not mandate that "documented procedures" are to be used to define anything. This shows a deep and fundamental misunderstanding of the process approach by Mr. Nelson -- who, by the way, was absent from TC 176 activities during the development of the process approach, so it's not clear where he got this viewpoint. ISO, TC 176 and the rest have repeatedly, clearly and vocally said how ISO 9001:2000 attempted to get away from "documented procedures" and into measuring the outputs of processes in order to ensure effective processes.
Mr. Nelson's divination of the thinking process of ISO TC 176 and their use of User Survey results is factually wrong on every level, and clearly derived from thin air in order to support his view. If anything, criticism should be laid at TC 176's feet for not using User Survey data at all. But they clearly didn't make the changes in 2000 in the manner he claims.
I really have to admonish Quality Digest for running stuff like this. I half wonder if I post a story that "ISO 9001 has always been about making boats out of fruit" it would get published without so much as a spell-check.
What Chris said
FTW.
The title's correct, though.
So wrong it's comical
This article is so wrong, it had me laughing all the way through. I hadn't realised QD had begun a comic parody line... Oh wait, actually it is intended to be serious. Really???
Like Chris Paris, I wonder what the editorial staff are up to or on, that they let it be published. it certainly does the magazine no good, to say the least.. Chris has done a great job in pointing out the numerous errors of fact and the convenient ignoring of pretty much everything that ISO has written about the Standard. After all, no sense in letting any thing get in the way of opinions, is there? Especially a tiddly little thing like evidence or facts. But then, who needs to bother about what ISO and the relevant Technical Committee have said, if you just want to spout a load of untruths?
What IS next from Quality Digest, wonder? The earth has been flat all along? Why the law of gravity is a complete furphy?
And why, oh, why are you actually publishing such utterly incorrect and silly opinionated nonsense? Jumping the shark, is a phrase that comes to mind for both author and magazine.
Jane Bennett
More wrongness
Another gross factual error: Mr. Nelson says, "Apparently resigned to the fact that management was going to use the standard as a basis for QMS design, the authors did what they could to promote application of a process approach by an audience with a standard-based mindset. The first attempt to stymie a standard-based mindset can be found in ISO 9001:2000 clause 0.1—Introduction, where it is stated that it is not the intent of the standard to compel uniform QMS structure and documentation."
Apparently Mr. Nelson has never read either the 1987 or 1994 versions of ISO 9001, which included the same statement, although worded a bit differently:
"It is not the purpose of these International Standards to enforce uniformity of quality systems." (Introduction, page vii) In fact, there's a whole paragraph on it.
This debunks his entire argument that the sentence was added to 2000, and therefore all of his incorrect assumptions about the rationale for such an addition. It was always there.
What is the purpose of this article?
Reading the academic explanations of how wrong we (users) understand the ISO 9001 it seems to find impressions of a persons that never redacted and implemented a QMS. Even the title, "You can shoot yourself in the foot trying to achieve customer satisfaction" confirm that. I have all respect for Mr. Nelson's experience but I thanks to God that I was never audited by his coursants. Just saying that we design and implement QMS conforming to ISO 9001 is not enough. The design of this important and useful tool for management shall be related to organization's culture, know how, resources and so on, as specified in Clause 01.
I ask Mr. Nelson to explain me why the companies which adopted this approach recorded real improvement?
And I ask Mr. Nelson what he tries to communicate through this article?
Words of wisdom
Yes Mr. Nelson, it's what they are: ISO 9001's paranoia on customer satisfaction - and continual improvement, which seems practically the same to me - leads organizations to strive for wrong, expensive, often useless objectives. Any standard is made of words, any word has more than one meaning, we've to be more careful when using words: they can hurt more than a sword.
