Inside Metrology
  |  06/09/2009
Using Air Gauging to Measure Taper in Orthopedic Device Manufacturing
Air gauges provide fast, easy, high precision results even under the toughest shop conditions.
(Mahr Federal: Providence, Rhode Island) --­ Tapers play an important role in orthopaedic devices. Most hip and knee implants use tapers because they provide good alignment and can be "locked" into position. In manufacturing these devices, the control of taper and size determines how well an implant performs over its lifetime. Increasingly, air gauging has become the inspection tool of choice for controlling these critical parameters.
"Air gauging was the breakthrough gauging technology of the '40s and '50s" says George Schuetz, director of precision gauges for Mahr Federal. "Introduced decades before electronic gauging, it provided the first high performance 50 µin. or better gauging on the shop floor. Despite its age, air gauging today is actually growing in popularity, especially in high precision areas like orthopedic devices. It is fast, easy to use, provides high precision results even under the toughest shop conditions, and can last for years measuring literally millions of parts."
For years the taper design of choice for orthopaedic devices was the simple round taper, Schuetz says. It functioned well, but with demands for better performance, new designs have been developed. Innovations such as special surface finishes and complex taper forms employing oblong tapers have improved orthopedic device performance.
But all these tapers offer unique challenges to gauge designers. "The problem is not just measuring taper or diameter," says Schuetz, "but measuring these dimensions on parts that may be only 12 mm in diameter and 12 mm in length. Even on parts that are longer, more points frequently need to be measured and more data collected."
Air gauging uses orifices that are 0.050 in. or smaller. They can be placed within 0.10 in. of each other and combined to produce any number of dimensional and geometric results. "Small electronic sensors or eddy current type sensors may approach the size of an air jet," says Schuetz, "but nothing can match air's economy or ability to work in a wet and oily shop environment right at the point of manufacture."
Air gauging uses the principle of back pressure to determine the size of a measured part, Schuetz explains. It is typically used for applications like precision medical tapers, where tolerance is fairly tight, usually less than +/-0.001 in., and surface roughness is less than 50 µin. Ra.
Medical implants take a beating and the taper fit between the female and male components is critical. The two pieces have to lock together and sit at the correct height. During manufacturing, it is common to inspect 100 percent of the parts to ensure the accuracy of both components, and air gauging offers three ways to do this.
The most common type of air gauge taper tooling has two pairs of jets on opposing air circuits, and is designed for a "jam fit" between the part and the tool. If the taper angle is incorrect, there will be excessive clearance between the two surfaces at one or the other end of the taper. Either situation can reduce the rigidity of the connection, which over time can cause the lock to fail. If the taper angle is correct but the size is incorrect, then the overall length of the orthopedic assembly will be incorrect and provide unexpected results after implant.
Jam-fit tooling does not measure part diameters, per se. Rather, it displays the diametrical difference at two points on the workpiece, as compared to the same two points on the master. To learn more about the taper components' positioning accuracy, you need a "clearance" style air tool in which an air taper ring cavity is sized to accept the entire taper part. Depending on where the part's reference surface is, the part can be referenced on the end of the taper or on a flange against the top surface of the part. This makes it possible to measure diameters at known heights. An additional set of jets may be added to inspect for bell-mouth and barrel-shape, two more conditions that reduce the contact area between the male and female components.
The third type of air taper gauge is a cross between the styles mentioned above. This is called a "simultaneous fit" taper gauge. It is basically a jam-fit air tool with an indicator that references on the face of the datum surface. This indicates how far the air tool goes into the part being measured. So while the air gauge provides a reading of the taper angle, the indicator provides an indication of the size of the diameters.
"But the best part about air gauging is that it's easy," says Schuetz. "The pressurized air from the gauge tends to clean the part as it's being measured, and production workers do not require special training to use air gauges. To check a hole, for instance, it is not necessary to develop skill in "rocking the gauge." To find the true diameter, merely insert the air plug in the hole and read the meter. It is as simple as that."
For additional information, contact:
Mahr Federal Inc.
1144 Eddy Street
Providence, RI 02905 USA
Phone: (800) 333-4243 or (401) 784-3100
Fax: (401) 784-3246
E-mail: information@mahr.com
Web: www.mahr.com
You can create content!
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
