Inside Quality Insider
Kevin Rudy  |  05/18/2012
Kevin Rudy’s picture
Snakes, Alcohol, and Checking the Residuals vs. Order Plot in Regression
Start with a summer morning, some runners, and some beer…
This past week, History premiered a new show called the United Stats of America. No, that’s not a typo. It’s a show hosted by twin brothers who are both stand-up comedians and obsessed with statistics.
Since I’m also obsessed with statistics (I’m still working on the stand-up comedy part), I thought I’d check it out to see if I could relate any of their stats to common applications of Minitab statistical software.
The show attempts to reveal some of the most interesting and surprising statistics in America. For example, only 8 percent of teenage boys use soap when they wash their hands. And once a year a meteor the size of a boulder hits the Earth with the destructive force of an atomic bomb (don’t worry; 70 percent of the Earth is covered in water, so odds are you’ll be OK). On top of that, more Americans are killed by deer each year than snakes. In fact, snakes aren’t nearly as dangerous as people think. Your odds of dying from a snake bite are about 1 in 50 million.
Photograph by Cotinis
And the odds get even safer if you’re sober.
Wait, did I just bring booze into this? Yes, yes I did. That’s because 40 percent of people who are bitten by a snake are also legally drunk. So after I erased “Hike the Grand Canyon while drinking” from my bucket list, I thought about this stat and decided that it makes sense. If you’re drunk, you’re going to be slower and less aware, thus giving the snake a better opportunity to bite you. But this made me wonder: How much slower do you get while intoxicated? That sounded like a great question for regression analysis.
Note: The following experiment was made up by me for illustrative purposes. I didn’t actually do any of this. But you can get my purely illustrative data here if you want to follow along.
On a clear summer morning, I gathered 40 people who knew their 100-yard-dash time. Then I randomly assigned each person a varying amount of alcohol to drink. When they were done, I recorded their blood alcohol content (BAC) and made them run a 100-yard dash. I recorded the difference between the time they ran intoxicated and their regular 100-yard-dash time (time difference). Here are the regression results:
The p-value for BAC is less than 0.05, and our R-squared value is 85.77 percent. I’d say we have a pretty good regression model. Of course, we’re not done yet; there are assumptions to check. I recorded each runner one at a time, and entered their data into Minitab in the order they were tested. So I should make a residuals vs. order plot to make sure the order of the runners didn’t affect the results.
The data should be randomly spread around zero. But wait, this plot doesn’t look random at all! Oops, I think I realized what happened. Remember when I said I did the experiment on a clear summer morning? Well, it took awhile to get through all 40 people, so that morning turned into a hot summer afternoon, which then turned into a cool summer evening. Runners who went early or late in the day didn’t have to deal with the heat, so their times were faster than expected (negative residual) based on the model. The runners in the middle had to run in the heat, so their times were slower than expected (positive residual). We can plot the residuals vs. the variable temperature to test this theory:
Yep, the residuals definitely increase as temperature increases. So what do I do? Well, one solution would be to redo the experiment somewhere with a constant temperature, like an indoor track. But if I don’t have the time for that, I could also add temperature to the regression model. Let’s do that and see what happens.
All right, that looks much better. Our R-squared value increased to 96.34 percent, and our residuals vs. order plot looks good: The data are now randomly scattered around zero with no patterns.
So now that my fake experiment is concluded, I am actually wondering if anybody has ever done a real experiment like this. If not, do I have any volunteers?
Kevin Rudy
Kevin Rudy is a technical communications specialist at Minitab Inc., developer of software and services for quality improvement and statistics education. Rudy has been a technical writer at Minitab since 2006 and he loves to combine the worlds of sports and statistics using techniques and tools that have applications in quality improvement and any other endeavor that involves the analysis of data.
