A research team at the Georgia Tech Research Institute (GTRI) has developed a software tool that enables users to perform in-depth analysis of modeling and simulation data, then visualize the results on-screen. The new data analysis and visualization tool offers improved ease of use compared to similar tools, the researchers say, and could be readily adapted for use with existing data sets in a variety of disciplines.
The data analysis and visualization tool is a subset of the Test Matrix Tool, a multicomponent system developed by GTRI for designing, executing, and analyzing large-scale modeling and simulation data sets. The visualization capability offers a graphical user interface that provides both on-screen data-manipulation features like filters and the ability to see query results in the form of graphical images almost instantly.
“Data visualization supports data analysis by letting users pose data-related questions on-screen with ease and then view the answers in ways that go far beyond ordinary table formats,” says Edward Clarkson, a GTRI research scientist who is leading the data visualization work. “A picture can be worth a thousand numbers, because visualizing data in a graph allows us to see patterns that might not be apparent from purely numerical results.”
Development of the Test Matrix Tool and its components is being led by Greg Rohling, a GTRI principal research engineer. Rohling’s team developed the Test Matrix Tool to support modeling and simulation investigations into the effectiveness and optimization of numerous U.S. defense systems, including electronic warfare equipment used to protect military aircraft. The work is supported by the Warner Robins Air Logistics Center at Robins Air Force Base.
In developing a simulation test, Test Matrix Tool users can specify desired variations in input parameters using multiple data filters. The Test Matrix Tool system executes all possible combinations of those parameters, creating a test matrix. It then executes the simulations on a Sun/Oracle Grid Engine and stores the resulting simulation output data in a MySQL open source database.
At that point, the Test Matrix Tool’s data analysis component, which includes the data visualization tool, helps users evaluate the often complex test results. By collating the test matrix input and output, the data analysis tools allow users to efficiently filter and visualize test matrix data.
The Test Matrix Tool is designed for use on personal computers. It works under the Linux and Microsoft Windows operating systems.
Some Test Matrix Tool capabilities, including the data analysis and visualization components, could be useful for scrutinizing information gathered in many disciplines, Clarkson says. He mentions health care as one field where a multitude of existing data sets could be mined for new insights.
“For example, there’s an enormous amount of data out there on heart patients,” Clarkson says. “Our data tools could be used to investigate existing patient information and seek significant trends in the data.”
Clarkson explains that users would face the challenge of organizing legacy data sets into formats that the GTRI data analysis software can exploit. But that task is generally straightforward and can be performed with automated tools in many cases, he adds.
The data format required by the Test Matrix Tool is not particularly complex, says Clarkson. What’s needed is a standard database setup in which the information fields are organized into tabular formats. Moreover, any required metadata—special data that tell the system how to deal with a particular data set—would likely present few development issues.
Clarkson recently demonstrated the capabilities of the data analysis and visualization tool using an existing database: baseball statistics. This particular demonstration involved the use of 40 different data filters available on-screen; the Test Matrix Tool system allows for 300 or more such filters.
In a random query of the 46,000 National League Baseball players from the past, an on-screen graph unexpectedly revealed an interesting anomaly during the demonstration. The data indicate that players’ height and weight increased in every past decade except the 1920s and 1930s, when it stayed inexplicably flat.
“That’s the beauty of this kind of tool—it can find the unknown unknowns,” Clarkson observes. “Details show up in graphs that aren’t obvious when you’re looking at just the numbers.”
The Test Matrix Tool’s data visualization tool bears some similarities to the data filtering features found on some websites, notes Clarkson. For example, many shopping sites let users search for products by using filters to select desired qualities such as size, color, and brand name.
However, Clarkson says, TMT’s capabilities are considerably more advanced. Whereas commercial systems stop at the filtering stage, the TMT data analysis tools allow fundamental manipulation of the data. Using filters, investigators can transform the data mathematically, a process that makes unique insights and discoveries possible.
“Data analysis and visualization are great for finding many things you want to know,” says Clarkson. “But another real advantage is that they can detect what you perhaps don’t want to know—the bugs and the anomalies—the things that just aren’t right and have to be fixed.”
