When every product manufactured is unique, clients often accept quality risks in order to deliver the project on time. Testing time is limited by the project nature of a manufacturing process and the metrics of quality change when compared to repetitive manufacturing. “Fixed delivery times, prototype manufacturing, and small enterprises lack the staff depth to monitor quality identically,” says Dennis Parass of Burlington, Ontario-based Questica, an engineer-to-order (ETO) technology firm.
Quality, often defined as the absence of any defect, must have the characteristics of a system that conforms to an original design. ETO products are unique and there’s often no original design. There are data from previous projects that possess similarities and help to guide quality and accuracy, but the notion of simply rerunning a job doesn’t exist in the ETO world of manufacturing.
Defining quality and the ETO challenges
A system of quality would have the following characteristics:
1. Maintainability (easy to add new functions)
2. Conformance to specifications (fulfilling end-user requirements)
3. Long mean time to failure (few bugs and abnormal terminations)
4. Performance that is adequate or as expected
5. Well tested for functionality, user interface, and performance
6. Well documented
7. Easy to use
8. Uses standard interfaces
“Assuming that quality is so defined, the challenges of ETO businesses to meet these criteria are significant, yet possible,” Parass says.
ETO: The challenges of quality
“The historical information found through effective templates and search wizards allows ETO users to identify prior designs and locate estimates and actual costs… where replicable quality control is axiomatically included,” Parass notes.
Custom Design is Unique | |
Because of constant changes: | |
...All causing a stream of releases from engineering | |
ETO firms can benefit from a quality nonconformance tracking system, because it permits users to raise network connections from several different areas, tracking the causes of problems and actions (as well as tracking costs to the project and jobs.) Because ETO is a style of manufacturing rather than any specific industry, following are some industries that are frequently challenged by quality that depends on the variable processes confronted in one-of-a-kind manufacturing.
Dies, Tools, and Molds | Machine Tools | Industrial Cranes and Hoists |
Farm Machinery and Equipment | Metalworking Machinery | Construction Machinery |
Foundry Equipment | Industrial Tractors and Trailers | Paper Industries Machinery |
Mining Machinery | Custom Boat Builders | Transportation Equipment |
Industrial Automation Equipment | Power Generation Equipment | Communications Equipment |
Oil and Gas Equipment | Conveyors and Material Handling Equipment | Fabricated Metals |
Medical Equipment | Food Industries Machinery | Custom Sign Makers |
Sign In to get started!
