Renishaw  |  02/19/2010
Renishaw’s picture
CMM Scanning Probe Retrofit Allows Fast Form Analysis
Renishaw’s REVO speeds impeller inspection times, additional data is used to compare inspected surfaces with 3-D CAD models.
(Renishaw: Torino, Italy) -- GE Oil & Gas, in Florence, Italy, has transformed the performance of a DEA Global coordinate measuring machine (CMM) with a REVO retrofit scanning probe system from Renishaw, producing higher data collection rates to allow form analysis—a function previously not practical due to the lengthy inspection times required. The retrofit, performed by Renishaw engineers, replaced the previous head, touch trigger probe, DEA controller, and PC-DMIS software, with the Renishaw Renscan5 system, including the REVO 5-axis scanning head, UCC2 controller, and MODUS, Renishaw’s metrology software.
The retrofit system's ability to reduce typical inspection times will facilitate collection of the additional data necessary for form analysis. “Our inspection time on a standard impeller was reduced by four times with the retrofit,” says Claudio Bartali, manufacturing technology project leader for GE Oil & Gas. “However, the exciting part will be using the massive amount of measurement data to compare the form of inspected surfaces with the 3-D CAD models.”
With a requirement for 100 percent inspection, there is a high demand on the CMMs and programming systems at the GE plant. The DEA Global is used to perform dimensional inspections on components varying in size and geometry up to 1,000 mm diameter.
REVO is a contact scanning probe with two integral measuring axes that can work in a true five-axis measuring mode when using the three axes of the CMM, allowing a completely different method of checking the impeller dimensions. The top face, for example, is measured with what Renishaw calls a “gasket scan,” a rapid sweep of the top machined face in about two seconds, gathering thousands of points. The previous method involved four touch trigger points and took close to 30 seconds. A best-fit calculation of the scanned data allows the software to plot a plane through all the points, confirming the position of the face and its relation to other surfaces. This large amount of data will be used to calculate if the surface is deformed in any way, and exactly which parts of the face deviate from the ideal CAD model of the component.
GE tested the accuracy of the new system by direct comparison of the touch trigger method to the REVO. “The accuracy of measured points was at least as good, but at considerably higher speeds and while gathering many more points,” says Paolo Trallori, calibration and metrology leader for the plant. “The lightweight head is extremely fast when measuring. With the speed of the machine’s axes movement no longer the limiting factor, the machine is often acting just as a carrier for the REVO. In most circumstances this means inspection moves can be 50 or 100 times faster than before. Some moves, like scanning the outside diameter of the impeller, are limited by the machine speed, but in this case, REVO still reduces overall inspection time.”
The DEA Global CMM, now capable of far higher data collection rates and form analysis.
By maintaining constant contact with the surface in one smooth rapid move, rather than moving on and off to take single points, inspection times are reduced and thousands of data points are gathered with the new system. “We will be able to certify the quality of components in terms of form tolerances, as well as simple dimensional tolerances,” says Trallori.
The Renscan5 system has been integrated fully into GE Oil & Gas’ production systems, with the Renishaw MODUS software executing inspection moves generated by a Unigraphics CAD/CAM system. The compatibility of MODUS with DMIS is very important, as the 3-D CAD model generated in the original design of the component is used for everything from machining the component to verifying its quality. Each component is tracked throughout the process by its serial number, with a full record of every stage of production. The new system allows GE Oil & Gas to add extra quality data to the record and further improve machining operations.
The DEA Global CMM with REVO retrofit scanning probe system inspects an impeller at the GE Oil and Gas plant in Florence, Italy.
A second machine, a DEA Scirocco with less volume for smaller impellers, is currently being retrofitted with a REVO system. Another larger gantry machine, for very large impeller parts, is also being considered for retrofit. “REVO has brought us a far better and more comprehensive method of inspection in a shorter time,” says Bartali. “Now we will be implementing quality standards for form measurement, something we could never do before.”
Florence is GE Oil & Gas’ business headquarters in Italy, with a global installed base of machinery and equipment of more than 20,000 units. Projects include the world’s largest LNG compression trains, re-injection of high sulfur gas, enhancing the safety and productivity of the world’s oil and gas pipelines, and equipment for the production of oil and gas from deep subsea resources. For more information about GE Oil & Gas visit www.ge-energy.com/business/ge_oilandgas .
Renishaw’s picture
For more than 30 years, Renishaw has been an innovator in metrology, the science of measurement, enabling measurements to be taken to international standards. The company's first product, the touch-trigger probe was invented by David McMurtry, now Sir David McMurtry, chairman and chief executive, to solve a specific inspection requirement for the Olympus engines used on the Concorde. The first Renishaw company was established in 1973 by McMurtry and John Deer, now deputy chairman. This innovative product went on to revolutionize post-process inspection of machined components.
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
