Inside Metrology
  |  07/28/2010
Product News: The ROTRONIC HygroLog HL-20/21
Compact, uncomplicated humidity and temperature data logging
(ROTRONIC: Bassersdorf, Switzerland) -- The new humidity and temperature data logger, HygroLog HL-20/21, from ROTRONIC expands on the HygroLog family of products.  The new logger is an economical and compact device that utilizes the latest AirChip 3000 technology and Hygromer sensors.
When combined with the HW4 software, all of the U.S. Food and Drug Administration (FDA) CFR 21 part 11 regulation and the Good Automated Manufacturing Practice (GAMP) guidelines of the United Kingdom are fulfilled.
Easy to use and versatile
The HygroLog HL-20/21 is perfectly suited to many applications, including those in critical areas such as pharmaceutical clean rooms, warehouses, production rooms, transportation containers, museums, and test facilities, or to ensure ideal temperature and humidity values in buildings and office environments. Programming, downloading, and graphing of recorded data is straightforward and uncomplicated with the HW4 software.
Compelling features
The HygroLog HL-20/21 has a large memory of up to 20,000 data points and a long battery life, allowing you to record through your most demanding applications. In addition to recording humidity and temperature it can be set to compute and display the dew or frost points. All recorded data is date and time stamped. The accuracy of the HygroLog HL-20/21 is unparalleled at 0.8-percent RH and 0.2°C.
Detailed information on the new HygroLog HL-20/21 and more about humidity and temperature measurement is available at www.rotronic-usa.com.
