Inside Metrology
Spectronics Corp.  |  03/02/2010
Spectronics Corp.’s picture
Product News: Digital Radiometer/Photometer Features Two-in-One Sensor
The XRP-3000 uses a dual-wavelength sensor detector to measure ultraviolet and visible light.
(Spectronics Corp.: Westbury, NY) --  Spectronics Corp. has introduced the revolutionary Spectroline AccuMAX XRP-3000 digital radiometer/photometer, the new benchmark in light-measurement technology. The XRP-3000 uses a dual-wavelength sensor detector to measure ultraviolet and visible light.
This microprocessor-controlled meter features automatic zeroing, integration, and signal hold. It provides standard UV intensity data as well as readouts of visible irradiance in various units, and is capable of accurately measuring a wide variety of nondestructive testing light sources. The LCD readout features ±0.2-percent linearity. The unit provides better cosine response than current generation radiometers. The AccuMAX also offers user-defined power save and automatic shut-off modes.
The AccuMAX features a sealed sensor housing and USB cable connection with a water-resistant adapter. A special self-sealing ring on the housing helps eliminate light leakage. The sensor detector can be coupled directly to the unit or connected via the included USB cable for greater versatility. In addition to the dual UV/visible light sensor, a luminance sensoris available for technicians performing radiographic examinations.
The XRP-3000’s rugged housing is equipped with a rubber protective boot for better grip and to prevent breakage if dropped. A slide-out panel allows easy replacement of the unit’s 9-volt batteries.
For more information about the AccuMAX meter, visit www.spectroline.com.
Spectronics Corp.
Spectronics Corp. manufactures more than 1,000 different UV, UV/Blue, and LED products for literally hundreds of markets and applications. Spectronics invented fluorescent leak detection in 1955 and has been the premier supplier of ultraviolet dyes and inspection lamps to the automotive, HVAC/R, and industrial markets for more than 50 years. Spectronics Corp.’s utmost dedication is to customer satisfaction throughout its research and development, manufacturing, sales, marketing, customer service, and logistical and technical support.
