Inside Metrology
Renishaw  |  10/15/2009
Renishaw’s picture
Product News: Linear Encoder for Sectional Machines and CMMs
Renishaw's new track-mounted encoder system combines accuracy, rugged stainless steel construction, and easy installation.
(Renishaw: Hoffman Estates, IL) -- Renishaw's new FASTRACK linear encoder scale system brings high accuracy, stainless steel construction, and quick, easy installation to large, sectional machines used in flat-panel display and photovoltaic manufacturing applications, as well as large coordinate measurement machines that require removal of the scale for transit. It is also ideal for linear motors with aluminum substrates and applications where thermal expansion of the scale must be independent of the machine structure, or those involving dissimilar axis materials, because the track-mounted scale can run across gaps up to 25 mm wide, while providing ±5 µm/m accuracy.
The FASTRACK system consists of two miniature guide rails that secure low-profile scales (8 x 0.2 mm cross-section) while allowing them to freely expand at their own thermal expansion rate with almost zero hysteresis. The scale can be installed, removed, and reinstalled as many times as required, and damaged scales can be pulled out of the guide rails and quickly replaced, even where access is limited, reducing machine downtime.
FASTRACK is available on reels for cut-to-length flexibility at the point of installation, allowing machine builders to minimize stock and lead-times. Generous tolerance makes measuring and cutting quick and easy. Easily installed, the self-adhesive guide rails feature integral prealigned sacrificial spacers, which are removed after the rails are fitted to the axis. The scale is then fed in from either end and locked to the substrate at a single datum point anywhere along the axis using cyanoacrylate glue or a clamp.
Part of a modular solution, FASTRACK can be used with either the RTLC stainless steel incremental scale and super-compact TONiC read head, or Renishaw's new RESOLUTE linear absolute encoder and RTLA absolute scale. The encoders in both set-ups feature advanced optoelectronics with resolutions to 1 nm, low subdivisional error (SDE), and very low jitter for smooth velocity control and rock-solid positional stability. For TONiC RTLC incremental scale installations, limit magnets and a reference mark selector are fitted to the FASTRACK and secured with a bolted clamp rather than using glue. The RTLC scale features multiple INTRAC reference marks at regular spacings.
The FASTRACK system is backed by Renishaw's global sales and support network and, like the TONiC and RESOLUTE encoder systems, it is compliant with the WEEE and ROHS environmental standards.
For a detailed look at other productivity enhancements for metrology, linear and rotary position feedback, and machine tool calibration, visit www.renishaw.com/encoders
Renishaw’s picture
Renishaw
Renishaw Inc. is a global company with core skills in measurement, motion control, spectroscopy, and precision machining. Renishaw develops innovative products to advance operational performance—from improving manufacturing efficiencies and raising product quality, to maximizing research capabilities and improving the efficacy of medical procedures. Renishaw products are used in diverse applications including machine tool automation, coordinate measurement, Raman spectroscopy, machine calibration, position feedback, CAD/CAM dentistry, stereotactic neurosurgery, and medical diagnostics.
