Inside Metrology
Delcam plc  |  03/16/2010
Delcam plc’s picture
Product News: Delcam to Launch R2 of PowerINSPECT 2010
The new release will incorporate automatic surface inspection and GD&T data.
(Delcam: Birmingham, UK) -- Delcam will launch the 2010 R2 version of its PowerINSPECT inspection software on stand No. 3514 at CONTROL 2010, at the new Stuttgart Exhibition Center in Germany, May 4–7. The new release will incorporate automatic surface inspection and the ability to use geometric dimensioning and tolerancing (GD&T) data from CATIA models, plus improvements to the handling of point-cloud data and changes to the interface to make the software even easier to use.
PowerINSPECT, a hardware-independent inspection software, combines the ability to work with all types of inspection devices with a comprehensive range of inspection routines for making simple measurements, inspecting geometric features, and checking complex surfaces. The resulting reports present detailed information in easy-to-read formats that can be understood by all engineers, not just inspection specialists.
The new automatic surface inspection methods for CNC coordinate measuring machines (CMMs) and machine tools use raster strategies taken from Delcam’s machining software. The user can set the distance between each point to be measured and the step-over between each line of measurements to develop a grid of data to be taken.
Each of these two key values can be set for each individual surface within the model, for groups of surfaces, or for the whole model. This allows a greater density of data to be collected from more critical areas of the component. For example, a mold maker might want to collect more comprehensive information from the core and cavity areas of a tool than from the split surfaces.
As with all PowerINSPECT strategies, the user can specify additional measurements to be made in any area of concern identified by the initial inspection.
The ability to extract GD&T data from CATIA models will allow designers to ensure that the correct design intent is measured in any prototype or production component. The designer can specify the required tolerances as the design develops and also specify the datums to be used for the inspection routine. The PowerINSPECT user can extract this information and use it as the basis for his quality control routines.
Inspection based on point clouds collected by laser scanners has been a development priority for PowerINSPECT for several releases, and this trend has continued in the latest version. The software now has the ability to align regions of the point cloud to specific, more critical areas of the model, rather than simply applying a best-fit routine over the whole part. In addition, new point-cloud registration functionality allows multiple point clouds to be aligned with each other, for example, when two sets of data are collected from opposite sides of the part. The combined data can then be used to generate a single report for the whole item.
The changes to the PowerINSPECT interface will make it easier to create inspection routines, especially for users of inspection arms and manual CMMs. This will be particularly helpful for occasional users of the software when creating inspection sequences that combine simple measures with geometric data.
For more information, visit www.delcam.com.
Delcam plc
Delcam is one of the world’s leading developers and suppliers of advanced CAD/CAM solutions for the manufacturing industry. Delcam’s range of design, manufacturing, and inspection software provides complete, automated CAD/CAM solutions, to take complex-shaped products from concept to reality. Delcam has the largest development team in the industry and keeps abreast of developments in machine tool and cutting tool technology. Headquartered in Birmingham, UK, Delcam is internationally known for providing the highest quality support from its subsidiaries and resellers throughout Europe, Asia, and North America (U.S. head office is in Salt Lake City).
