(Danatronics: Danvers, MA) -- Danatronics Corp. has introduced the ECHO 9 Series of ultrasonic thickness gauges. The series combines more than 50 years of ultrasonic know-how into an extremely versatile and easy-to-use ultrasonic thickness gauge.
Packaged in a custom-designed, IP67-rated case, the ECHO 9 combines both a corrosion and precision thickness gauge into one unit. In its most popular configuration, ECHO 9 is an extremely capable ultrasonic thickness gauge for measuring the wall thickness of metal structures subject to corrosion.
Key features of the ECHO 9 include:
• 3.5-in. sunlight-readable color display
• Rechargeable lithium ion battery via USB port
• 32-character file name and 20-character ID with essentially unlimited memory via removable SD card up to 32 GB
• Wide thickness range of 0.006-23-in. in steel, depending on probe and mode of operation
• Graphic display with multiple on-screen languages
• Field-upgradable software options for Datalogger with b-scan, real time A-scan, and precision gauging 0.0001-in. or 0.001 mm resolution
• Vibrate and change color on alarm
• Fast min/max displays actual as well as min/max thickness readings simultaneously
• Recalibration notification
• Available in custom rubber boot with built-in stand and four-point chest harness
• Datalogger interfaces with Microsoft Excel
• Designed for IP67
• Two-year warranty
• Made in the USA
The ECHO 9 series is the perfect gauge for customers demanding the most versatile, easy-to-use instrument on the market.
Contact Danatronics at www.danatronics.com or (978) 777–0081 for more details.
