Inside Metrology
  • SUBSCRIBE
Meggitt  |  08/03/2012
Meggitt’s picture
Piezoelectric Reaction Shaker System for Structural Testing
Meggitt Sensing’s Wilcoxon Research model F7-1 provides sonic and ultrasonic excitation over a range of 1 Hz to 80 kHz
(Meggitt Sensing Systems: San Juan Capistrano, CA) -- Meggitt Sensing Systems, designer and manufacturer of sensing and monitoring systems, has introduced its Wilcoxon Research model F7-1, a portable piezoelectric shaker system designed to provide sonic and ultrasonic excitation over a range of 1 Hz to 80 kHz, in support of extreme field structural testing requirements, such as those common to missiles, weapons, and satellite components, as well as shearography, biomedical research, mechanical impedance studies and high-frequency vibration monitoring.
As a “reaction mass” shaker system, the Wilcoxon Research model F7-1 is designed to produce a force at its attachment point on the face of the shaker “head,” where it attaches to a structure. It does not produce vibration motion relative to the shaker case. The shaker operates by exciting piezoelectric elements attached between the shaker head and reaction mass. These elements produce small displacement changes between the mass and head, resulting in the generation of forces into the structure that is attached to the shaker head. Under normal use conditions, the F7-1 would be attached to a structure much more massive than the reaction mass, with that mass doing most of the “moving” in response to piezoelectric element excitation.
With a portable, lightweight design weighing just 1.27 kg (2.8 lb), ideal for on-site field testing, the Wilcoxon Research F7-1 is designed to be used with a matching network (model N8HFS, sold separately), providing voltage step-up to the drive share at full voltage levels, as well as a power amplifier, also available separately as the model PA8HF. Models are shipped with directly compatible cable (model F4-4M-J9-10) to mate to the matching network. The matching network is further supplied with the compatible cable (model R22-22-J9B-5) that connects to the model PA8HF power amplifier.
For detailed technical specifications, drawings, or additional information, visit www.meggittsensingsystems.com.
Meggitt’s picture
Meggitt
Meggitt Sensing Systems is a Meggitt group division specializing in sensing and monitoring systems that measure physical parameters in the extreme environments. Meggitt Sensing Systems has operated through its antecedents since 1927 under the names of Ferroperm Piezoceramics, Lodge Ignition, Endevco, Sensorex, ECET, Vibro-Meter, and Wilcoxon Research. Today, their capabilities and facilities have been integrated to one Meggitt division, providing complete systems from a single supply base. Meggitt’s piezoresistive, Isotron and variable capacitance accelerometers, piezoresistive pressure transducers, acoustic sensors, electronic instruments, and calibration systems ensure critical accuracy and reliability within aerospace, automotive, defense, industrial, medical, power generation, R&D, space and test and measurement applications.
