(Bruker: Santa Barbara, CA) -- Bruker, developer, manufacturer, and provider of scientific instruments and analytical services, has released the new PeakForce Kelvin Probe Force Microscopy (KPFM) mode for its line of atomic force microscopes. PeakForce KPFM utilizes frequency-modulation detection to provide the highest spatial resolution Kelvin probe data. It builds on Bruker’s exclusive PeakForce Tapping technology to provide directly correlated quantitative nanomechanical data, which improves the sensitivity of the frequency-modulation measurement and eliminates artifacts. In addition, PeakForce KPFM provides a completely automated parameter setup with ScanAsyst. The result is a significant improvement in quantitative surface potential data for materials research as well as semiconductor applications.
“Our research and industrial customers have increasing needs for quantitative nanoscale property measurements,” says Mark R. Munch, Ph.D., president of Bruker Nano Surfaces Division. “Our new PeakForce KPFM mode combines leading-edge spatial resolution with unprecedented sensitivity and accuracy in work function measurements.”
“We are committed to move AFM beyond just imaging contrast to quantitative electrical and mechanical property maps,” adds David V. Rossi, executive vice president and general manager of Bruker's atomic force microscopes business unit. “To enable this advance, we are building on our exclusive PeakForce Tapping technology with PeakForce QNM, PeakForce TUNA, and now PeakForce KPFM.”
The PeakForce KPFM accessory is an optional addition available for the Dimension Icon and MultiMode 8 atomic force microscopes. It includes the complete set of KPFM detection mechanisms (amplitude and frequency modulation), in conjunction with both TappingMode and Peak Force Tapping, as well as the ability to perform KPFM measurements over an extended voltage range. Its signature PeakForce KPFM mode combines FM-KPFM detection with PeakForce Tapping technology. This combination enables more sensitive potential detection with optimized probes. It eliminates the contamination of FM-KPFM signals with mechanical cross-talk, retaining more accurate measurements even on samples with significant variation in adhesion or modulus. Those variations can be mapped simultaneously and independently at highest spatial resolution using PeakForce QNM. The ScanAsyst concept has been extended to KPFM, providing fully automated parameter setup to guarantee optimized results.
