Measurements add value to the parts you manufacture. That may not be a widely accepted position, because the act of measuring is an additional step in the manufacturing sequence, and every step has a cost associated with it. With pressure to reduce costs and improve productivity, some might think that eliminating the measuring steps would do just that. If they could only make their manufacturing process accurate and consistent enough, measuring would be unnecessary and, therefore, not measuring would lower their total costs. How valuable are the measurements you make? Cost of measuringSign In to get started!
