Inside Metrology
Fluke Corp.  |  09/02/2009
Fluke Corp.’s picture
Why You Need Thermal Process Monitoring
In process manufacturing, temperature uniformity is essential.
I
n process manufacturing, temperature uniformity is essential. Technicians rely on monitoring of all kinds, from fixed mount sensors to hand-held thermal imagers to track the condition of product and critical equipment. That’s because temperature measurement and control is one of the single most significant variables for uniformity across process industries.
Temperature monitoring can detect overheating delivery system components, help solve irregularities in electrical power supplies, predict operational machinery failure, detect blockages in supply pipes, and identify product inconsistencies.
Given the number of process industries and associated equipment variations, the possibilities for thermal monitoring are endless. One approach is to provide the most monitoring to critical assets, followed by equipment in harsh environments. For example, the sludge, solvents, and particulates found in many processes put extra stress on motors and affect bearings, windings, and insulation.
That stress shows up as heat detectable by a thermal imager.
This thermal image highlights uneven
cooling on a cooled paper roller.
What to check
Power distribution systems. Consistent, high-quality power is essential for process manufacturing. Thermal imagery can identify bad electrical connections, imbalances, overloads, harmonics, and other impending electrical equipment failures and prevent both uneven or inadequate power supply as well as downtime.
Motors, fans, pumps, conveyors. Thermal inspections of the bearings, shafts, casings, belts, gearboxes, and other components that emit heat before failure can prevent unexpected equipment breakdowns on moving equipment.
Heat processes. Paper, glass, steel, and food product production all require the uniform application of heat. These processes often utilize thermocouples or infrared temperature sensors for thermal control. Frequently, spot measurements are not adequate due to process variations. Line scanners provide continuous thermal profiling in these cases, while portable thermal cameras can troubleshoot problems and determine the optimum spot to install the thermocouple or infrared sensor.
Pipes. In processes, fluids need to be delivered to the right place at the right time and in the right amounts. If a pipe is obstructed, it can cause a chain reaction that throws an entire process loop out of tune, creating oscillation. This will cause motors to cycle on and off too frequently, which in turn causes more frequent current surges that stress the electrical system and add harmonics that lower system efficiency, and ultimately lead to equipment failure.
Thermography can often pinpoint an obstruction, allowing corrective action before the whole loop goes down, and the loop can be recalibrated by a multitasking technician using loop calibrators and digital multimeters.
Valves. Process control valves are also critical to delivering fluids to processes at the right time. A thermal imager can monitor for leakage, stiction (static from friction), or excess friction. Also, a valve’s excitation coil may overheat from working too hard, pointing to a problem such as current leakage or valve size mismatch. When thermography indicates a problem, technicians can follow up by calibrating the valve or the valve’s positioner.
By scanning product at different points in production as with these cookie and cracker production lines, thermal imaging can help spot check quality and troubleshoot irregularities.
What to look for
In specific processes, use your thermal imager to look at product uniformity. For example, if you have a paper process, you probably process the paper by running it through an oven to cure it. The coatings applied often require a combination of time and temperature to achieve the right cure point and final moisture level.
Use your hand-held thermal imager to examine the thermal uniformity of the product as it comes out of the oven. Thermal variations are often attributable to other process variables such as irregular uniformity in moisture or cure.
In general, use your hand-held thermal imager to look for hotspots, cool spots, and other anomalies. Here are some suggestions about critical equipment to monitor and what thermography might detect: motors (hot bearings and windings), motor control centers and switchgear (imbalance, overloads), team systems (failed traps, obstructed piping), cooling systems (fouled cooling towers, blocked heat exchangers), furnaces and boilers (damaged refractory, leaking ports), pumps (hot bearings, leaking seals), process piping (ineffective insulation, reduced flow), tanks and vessels (product or sludge levels, leaks), valves (leakage, stiction), and conveyors (hot bearings and drives).
Each time you inspect a piece of equipment, save a thermal image of it on the computer and track its condition over time. That way, you’ll have baseline data for comparisons that will help you to determine whether a hotspot (or cool spot) is unusual or increasing over time and also to verify when repairs are successful.
What represents a “red alert”?
Equipment conditions that pose a safety risk should take the highest repair priority. However, the imminent failure of any piece of critical equipment constitutes a red alert. The same key operations, maintenance, and safety personnel who determine which production assets are critical should play important roles in quantifying “warning” and “alarm” levels for those assets.
(Note: Alarm levels for specific equipment can be set on Fluke hand-held thermal imagers.)
Potential cost of failure
Here are representative hourly downtime costs for some selected process industries: energy, $2.8 million; pharmaceuticals, $1 million; food and beverage, $800,000; chemicals, $700,000; metals, $550,000. These figures are tied to loss of IT performance but are cast in terms of general downtime.*
*Sources: IT Performance Engineering and Measurement Strategies: Quantifying Performance and Loss, Meta Group, Oct. 2000;
Fibre Channel Industry Association as found on the web site of the Association of Contingency Planners, Washington State Chapter (www.acp-wa-state.org).
Fluke Corp.
Fluke Corp. is a world leader in the manufacture, distribution, and service of electronic test tools and software. Since its founding in 1948, Fluke has helped define and grow a unique technology market, providing testing and troubleshooting capabilities that have grown to mission critical status in manufacturing and service industries. Primary market segments served include industrial/electronic service installation and maintenance, electrical and temperature, indoor air quality, calibration, and biomedical.
