Inside Metrology
Michael Raphael  |  02/03/2010
Michael Raphael’s picture
3-D Scans of Matisse Sculptures Reveals Artist’s Methods
3-D scanning is the future of art history research.
3-D digitizing technologies have been utilized in the industrial world for the last 20 years but are increasingly used in many other fields. One of the exciting, but unanticipated, uses of 3-D measurement tools has been their adoption by museums for sculpture conservation, research, and interactive exhibits.
3-D scanning is a perfect fit for documenting museum pieces. Museums, for example, typically have pieces that cannot or should not be touched, yet present tremendous opportunity for study, documentation, interactive presentation, or scaled for one-to-one reproduction. The great news is that with one scan, all of the above can be achieved without any physical contact with the work of art.
Direct Dimensions Inc. (DDI) first became involved with scanning sculptures for research purposes in 2004 when they were approached by the Baltimore Museum of Art (BMA) to scan two castings of Antoine Louis Barye’s “Tigre qui Marche” (The Walking Tiger). The BMA was interested in dimensionally inspecting and comparing two of the (many) existing castings. Direct Dimensions laser scanned the two tigers with a Faro Scan Arm and overlaid the two resulting 3-D models to compare them.
The BMA was so pleased by the outcome of the Barye effort that they engaged Direct Dimensions again, on a much larger project. In 2007 and 2008 they mounted a large show, Matisse: Painter as Sculptor and the curators were interested in applying some of the same 3-D scanning techniques to their research. In particular, they were interested in how the technology might illuminate the creative process of Matisse as a sculptor.
The Direct Dimensions team focused on two sets of sculptures: different castings of Matisse’s “Reclining Nude I” (Aurora) and “Magadliene I” and “Magadliene II.” In the case of the Reclining Nude, curators were interested in comparing multiple castings to see how they may be related to one another. As for the Magadlienes, there was a theory that Magadliene II had been cast from the plaster cast of Magadliene I. BMA curator Ann Boulton hoped that a dimensionally accurate inspection (detecting differences as small as tenths of a millimeter) might shed light on the theory.
After working closely with the BMA staff to understand their research interests, the 3-D scanning technicians opted to use a Faro Arm and Faro Laser Line scanner. The arm and scanner combination can capture data with an accuracy of ±0.002 in., allowing every fine, hand-worked detail to be captured without ever touching the sculptures. The arm and scanner are also portable so the artwork never left the safety of the museum.
Back in their office during the next few weeks, the DDI team used Innovmetric’s PolyWorks Modeler software to process the raw laser data into 3-D digital replicas of each of the sculptures. The 3-D models of the sculptures enabled exciting discoveries.
The three models of Reclining Nude were superimposed over one another in a dimensional analysis. The superimposed image is visualized as a color mapped figure that shows where the castings deviate from each other. The team at Direct Dimensions and the BMA discovered that two of the castings were essentially identical (both had been cast from the same mold) while the third was approximately 4 percent smaller, indicating that it was a “cast off” or copy of one of the originals.
The Magadlienes’ analysis differed from the analysis of the Reclining Nude because entire superimposed models were not necessary. The curators were trying to find specific similarities, so the team at Direct Dimensions took specific cross sections from each of the models and compared the cross sections. The results from the cross section analysis indicated that though large parts of the sculptures were different, the close measurements in the torso and head section indicated that the second sculpture was indeed created from the first. This major discovery was an important insight into Matisse’s artistic process.
In addition to enabling important research, the 3-D scan data was used in two multimedia presentations supporting the exhibit. The same data used for the research and presentations can also be used to create high quality replications.
Additional research
The Matisse: Painter as Sculptor exhibit is just one example of a fine art application for 3-D scanning and imaging technologies. Recently, Direct Dimensions has also worked with MOMA, The National Gallery of Art, The Getty, The Walters Art Museum and BMA on additional conservation and research projects. 3-D scanning for technical examinations of museum collections is just starting to gather steam and it is exciting to imagine what future research will bring.
To see images of the scanned Matisse sculptures, visit the Direct Dimensions web site.
Michael Raphael
Michael Raphael is founder and president of Direct Dimensions Inc., a Baltimore-based company offering a full range of 3-D imaging services including reverse engineering, dimensional inspection, and 3-D scanning. Direct Dimensions has been providing solutions for a wide range of fields from manufacturing, engineering, and design to art, sculpture, and architecture for nearly 15 years.
You can create content!
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
