Inside CMSC
CMSC  |  05/17/2009
CMSC’s picture
Delcam Previews New PowerINSPECT at Control
(Delcam International Inc.: Windsor, Ontario, Canada) -- Delcam previewed the forthcoming version of its PowerINSPECT inspection software at the Control exhibition held in Stuttgart, Germany, May 5–8.  This new release of the world’s leading hardware-independent inspection software is scheduled for release in the summer and will include a range of enhancements to make it easier and more flexible to use.
The most obvious change will be a completely new interface for undertaking “simple” measurements. This will make it much easier to undertake basic tasks, such as measuring the distance between two points or two planes, or the centers of two circles, or checking the thickness of a section.
It has also been made easier to add or delete points during an inspection from a set of measurements defining any feature. Points might need to be added to collect extra data from a suspect area, while “rogue” measurements can be deleted to prevent them from affecting the overall inspection.
A number of improvements have been made to the ways in which data within geometric features can be handled. The attributes of each point making up the sequence will be able to be displayed separately, either as the renowned PowerINSPECT dots or as needles proportionate in length to the extent of the deviation. This will make it easier to see where the problems areas are, especially in bigger parts with large numbers of measurements.
It will also be possible to use individual points within multiple features. For example, two sets of points could be used to check the circles at the top and bottom of a cylinder and then combined to produce the inspection report for the cylinder itself.
Increased flexibility will also come from the new ability to display feature measurements as surface points for comparison with the CAD model. This will make it easier to spot errors when, for example, a circle is perfect in its own dimensions but is not in exactly the correct position on the part.
One simple enhancement that could save considerable time will be the ability to halt an inspection during the measurement sequence. This will allow the operator to produce a report as soon as the part is found to be out-of-tolerance, rather than having to complete the full sequence. It will be particularly helpful when inspecting more complex components in a production environment.
PowerINSPECT’s easy-to-understand reporting has always been one of its most popular attributes. This has been further improved with the ability to display an image of the part on each page of the report showing just the measurements listed on that page. This will make it easier to analyze the results from large sets of data, for example, results collected with laser scanners.
CMSC’s picture
CMSC
Founded in 1984, the Coordinate Metrology Society (CMS)—presenter of the Coordinate Metrology Systems Conference (CMSC)—is a large society of users, service providers, and OEM manufacturers of close tolerance, industrial coordinate measurement systems, software and peripherals. These metrology systems include traditional CMMs, electronic theodolites, laser projection systems, laser trackers, laser radar, photogrammetry and videogrammetry systems, scanning devices, and articulating arms. The society assembles at the CMSC to learn about advancements in use or development of any measurement system or software that produce, utilize, and analyze 3-D coordinate data.
